Old 01-02-2007, 09:30 AM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default ISU Blocked URL?? HELP...
Yesterday i installed a software which was meant for hiding the IP address of a computer.
When i started it, it assigned IP address of Saudi Arabia to me.
Now when i connect and try to access ORKUT.com, it says ISU Blocked URL.
Wat is the problem??
Wat can i do ??
Y is it saying that??
Manshahia is offline
Old 01-02-2007, 10:46 AM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: ISU Blocked URL?? HELP...
Just uninstall 'Hide IP Platinum'
Third Eye is offline
Old 01-02-2007, 10:53 AM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
HIDE IP uses Proxy Servers and have a List of Good and Fast Proxy Servers on Planet
Most Proxies will block some domains...so all you can try is STOP using HIDE IP or change Proxy some other country in HIDE IP
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 01-02-2007, 11:42 AM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
Ok. Thnx. Done it.
Old 01-02-2007, 12:04 PM   #5 (permalink)
Google Bot
Pathik's Avatar
u cn still use hipe ip platinum... jus change ur ip to some other countrys...
Pathik is offline
Old 01-02-2007, 12:23 PM   #6 (permalink)
Resident Fanatic
Manshahia's Avatar
I tried again and again, but it always assigns me an IP address of Saudi Arabia.
- by gforz
