Old 17-01-2005, 08:23 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default IE fails to open
my friend's PC is a pIII with 1GHz. with win98 OS and 128 MB RAM ...
when we click on the IE icon in the desktop IE refuses to open ....
we went to c:\program files\(IE folder) and clicked on iexplore.exe ...... IE refuses to open
he connects to the net n browses by clicking the "MyComputer" icon and types the URL the websites open normally ...
how do i fix the IE icon error .... IE fails to open on doubleclicking the IE icon ...
mekalodu
iinfi is offline
Old 18-01-2005, 02:08 PM   #2 (permalink)
tuxfan's Avatar
Go to Add/Remove Programs, click on IE and click on Add/Remove. There you will get an option for repairing IE. Try that.
tuxfan is offline
Old 18-01-2005, 02:21 PM   #3 (permalink)
mekalodu
iinfi's Avatar
Default tried that not working
hi tuxfan .....
thats not working .......
i even reinstalled IE on top of the existing one ... thats not working either
i reinstalled win98 on top of te existing one .... no use ....
mekalodu
iinfi is offline
Old 19-01-2005, 12:30 PM   #4 (permalink)
tuxfan's Avatar
Well, if reinstalling Windows also doesn't work, I wonder what will!! I fear you may have to go for a clean re-install for this to work. Or wait for some one who knows more than me.
If you are wanting to use IE for browsing, believe me, it is in your own benefit that it isn't working :roll: Try using Firefox. Either you can download it or install from Digit/PCQuest CDs. Install version 1.0.
tuxfan is offline
Old 19-01-2005, 02:02 PM   #5 (permalink)
TRY FIREFOX.
Lovedeep Wadhwa
cheetah is offline
Old 19-01-2005, 02:18 PM   #6 (permalink)
swatkat's Avatar
Whenever u double click the iexplore.exe,check that is there any process called iexplore.exe is running by using CTRL ALT Delete.
If the pocess IS running but Explorer is not opened,then it may due to some Virus or Spyware problem.
Scan the system using any of the updated AV and AntiSpywares like, Microsoft AntiSpyware
SpyBot SnD
AdAware
Some good AV
System Mechanic etc.
http://swatrant.blogspot.com/
swatkat is offline
Old 19-01-2005, 03:19 PM   #7 (permalink)
mekalodu
iinfi's Avatar
Default yeah iexplore.exe is running
i tried Ctrl + alt + del b4
ieexplore.exe is running .... i will try cleaning it with spybot ..
thanks for the suggestion
mekalodu
iinfi is offline
- by gforz
