Old 30-01-2007, 10:21 PM   #1 (permalink)
144
144's Avatar
Default Help needed urgently.
System info:
Processor: Intel® Core™2 Duo E6600
Mainboard: Intel® (CLASSIC SERIES) DP965LT
RAM: Kingston® DDR2 667MHz 1GB x 1 Piece
Graphics Adapter:nVidia® 7600 GT PCIe Card (256MB)
HDD: Maxtor® 160GB SATA HDD
Optical Dirve: Samsung Combo DVD-R/CD-RW
OS:Microsoft® Windows XP Professional SP2 (Updated)
Anit-virus:AVG Free Edition 7.5.432 (Updated and scanned regularly)
Anti-Spyware:AdAware SE personal Build 1.06r1 (Updated and scanned regularly)
Router: D-Link DI-524 AirPllus™G -Rev B4 (Firmare version:V2.04b02)
System problems:
1. Many applications hang-up frequently (Namely Photoshop (CS3 Beta), utorrent, Intel® Desktop Utilities).
On App hangup - Ctrl-Shift-Esc doesn't bring up the Task Manager. Ctrl-Alt-Dlt brings up the TaskManager option on clicking which, again nothing happens. Doing this in a sequence brings - Many task manager icons into the system tray yet not accessible.
One any app hangup nothing is accessible. That include everything as in Mouse is not clickable over anything. NumLock works.
Only option left in this circumstance is to re-boot via Reset.
2.uTorrent downloads - I am downloading via utorrent, and my torrents are at a very low speed,. I am on WLAN network with a speed of 2Mbps, yet I get close to 0.8kb/s download. Upload is at 1.7kb/s. I contacted my ISP who admits that there is a congestion in the network slowing it down - yet they also disagree for speeds to become as slow as mine.
I have done the 'port forwarding' on my router - I have tried to optimize the UL/DL settings in utorrent (with help from a source on the web)
3.MSN fails to connect sometimes. I have set the firewall settings of my router to allow MSN. Yet it fails sometimes. Eventhough it is connected, I get a message delivery failure notice too many a times.
I have tried bypassing my router(connecting the cable directly to ISP)... But its the same.
My main concern is my PC becoming slow. The processor is supposedly dual core .. am I right? I am monitoring the Temperatures on the processor and board via Intel Desktop utilities. They r in normal limits round the clock...
I need help. ASAP.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 30-01-2007, 10:58 PM   #2 (permalink)
Arsenal_Gunners's Avatar
Default Re: Help needed urgently.
the hangups may be of because these reasons.
1.virus(which you say you scan regularly)
2.overheat(you moniter the temperature regularly)
3.RAM-This may be causing the problem check it by memtest86
http://www.memtest86.com/memtest86-3.2.iso.zip
Arsenal_Gunners is online now
Old 31-01-2007, 08:16 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
post a Hijack This Log here,
do a Full System Virus Scan & Spyware Scan in Safe Mode
download- HijackThis
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 31-01-2007, 01:29 PM   #4 (permalink)
::cyborg::'s Avatar
ya post ur hijack log
:)) - KEEP SMILING
::cyborg:: is offline
Old 01-02-2007, 11:57 PM   #5 (permalink)
144
144's Avatar
Logfile of HijackThis v1.99.1
Scan saved at 2:25:37 AM, on 2/2/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\RunDLL32.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
C:\Program Files\PowerISO\PWRISOVM.EXE
C:\Program Files\Intel\IDU\iptray.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\Java\jre1.5.0_10\bin\jusched.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\Mozilla Firefox\firefox.exe
D:\downloads\utorrent.exe
C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroTray.exe
C:\Program Files\Adobe\Adobe Photoshop CS3\Photoshop.exe
C:\Documents and Settings\-\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyOverride = *.local
O2 - BHO: IDM Helper - {0055C089-8582-441B-A0BF-17B458C2A3A8} - C:\Program Files\Internet Download Manager\IDMIECC.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O4 - HKLM\..\Run: [IntelAudioStudio] "C:\Program Files\Intel Audio Studio\IntelAudioStudio.exe" BOOT
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RunDLL32.exe NvMCTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [ipTray.exe] "C:\Program Files\Intel\IDU\iptray.exe"
O4 - HKCU\..\Run: [IDMan] C:\Program Files\Internet Download Manager\IDMan.exe /onboot
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [µTorrent] "D:\downloads\utorrent.exe"
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O4 - Global Startup: Adobe Acrobat Synchronizer.lnk = C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AdobeCollabSync.exe
O8 - Extra context menu item: Append to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Download All Links with IDM - C:\Program Files\Internet Download Manager\IEGetAll.htm
O8 - Extra context menu item: Download with IDM - C:\Program Files\Internet Download Manager\IEExt.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~3\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~3\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~3\INetRepl.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O10 - Unknown file in Winsock LSP: c:\program files\bonjour\mdnsnsp.dll
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
O23 - Service: Admin Works Agent X8 (AWService) - OSA Technologies Inc., An Avocent Company - C:\Program Files\Intel\IDU\awServ.exe
O23 - Service: ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762# # (Bonjour Service) - Apple Computer, Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
144 is offline
- by gforz
