As you play video, a temp file get downloaded to your PC. To access it go to Tools>internet options>temporarary internet files> settings>view files . There if you search for files like *.flv or *.swf you will find your file. just copy it to someplace and and on to cd.
opera 9 provides an option to save web page with images.. those images will be in a folder.. some files will have ext.. .swf which is a saved flash file.
to open that you can use IE or opera itself
There is a software called FlashCapture from dreamingsoft, which can save the flash file. It is not a freeware, you may download it from www.dreamingsoft.com
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
