Old 17-01-2005, 02:28 PM   #1 (permalink)
Default MSN Messenger 7 (beta)
I use msn messenger 7 (beta). Since i have 2-3 hotmail ids, i check their inboxes thru msgr itself. Now, in the login window (where u hv to type ur id n p/w), i see a number of email ids in the drop down menu - which r old n i dont use.
how do i get rid of these entries???
futuristically_ancient is offline
Old 17-01-2005, 03:49 PM   #2 (permalink)
Check the registry for entries with ur username. Check some files in the installation folders. Check help. Google for help. Then post messages in the forum.
Life is weird,so am I.
jetru is offline
Old 17-01-2005, 04:41 PM   #3 (permalink)
 Macboy
goobimama's Avatar
First of all, jetru, that is some horrible advice.
Anyway, the trick to get rid of extra ids, go to control panel >user accounts> select your username> then go to "manage my network passwords". There you will be able to delete the information stored for those extra IDs.
That's it.
Milind
I'm like a bird... :)
goobimama is offline
Old 17-01-2005, 05:13 PM   #4 (permalink)
dun pi$$ me off jetru!!!!
if u know how my problem can be solved, only then reply........otherwise .............SHOVE OFF!!!!! U aint got ne personal liberty to post here. im a member of this forum, n i can post!!!
Also, the forum's name is QnA - which means u can post ur queries here.
GOT NETHING INTO UR STUPID HEAD?!?!?!
THANKS MILIND! UR SUGGESTION HELPED ME OUT!!
CHIAO!
- by gforz
