Old 29-01-2007, 10:59 PM   #1 (permalink)
Default Flash import help
I want to import a folder containg 60 images as a frames(i image in each frame)
Is it possible.Idont find an option to do it?
Can anyone help me?
mukilan is offline
Old 29-01-2007, 11:06 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Flash import help
You can import images in library or directly to the stage. Goto File>Import>Import to Library. I dont think its is possible to import images as frames. You need to do that manually.
blueshift is offline
Old 29-01-2007, 11:17 PM   #3 (permalink)
Thanks for the reply.But i figured it out.Just select the File-> import and select the first image in sequence(image01.png)and flash automatically imports as frames
mukilan is offline
- by gforz
