Old 29-01-2007, 07:19 PM   #1 (permalink)
Default Folder undeletable
Can any 1 tell me how 2 make any folder & my documents undeletable ?. They are on the desktop.
thunderstorm_08 is offline
Old 29-01-2007, 07:27 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Folder undeletable
check for a sw here at http://www.dirfile.com/freeware/folder.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 29-01-2007, 07:56 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Undeletable or deletable??
For deleting proceed as said by koolbluez.
Use Folder Lock for password protecting and hiding them.
Nokia N86 8MP
Lucky_star is offline
Old 29-01-2007, 08:03 PM   #4 (permalink)
I think u should use softwares .I think u shouldnt use folder lock it is easily breakeble.If u want to create a new folder like the one of the my document u can do by following the steps given below.
Create the following series of keys and values in the registry at [HKEY_CLASSES_ROOT\CLSID] or [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID]. The GUID, globally unique identifier, can be a random number, in this example "FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345" is used.
Create a new key called [HKEY_CLASSES_ROOT\CLSID\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}] and set (Default) to equal the name of the folder e.g. "My Folder".
Create a new sub-key under the main key called "DefaultIcon" (i.e. [HKEY_CLASSES...ABCD1DE12345}\DefaultIcon]) and set (Default) to equal the filename for the icon you want to display e.g. "c:\windows\myicon.ico".
Create a new sub-key under the main key called "InProcServer32" (i.e. [HKEY_CLASSES...ABCD1DE12345}\InProcServer32]) and set (Default) to equal "shell32.dll", also create a new String value called "ThreadingModel" and set it to "Apartment".
Create a set of sub-keys starting at the main key "Shell\Open My Menu\Command" (i.e. [HKEY_CLASSES...ABCD1DE12345}\Shell\Open My Folder\Command]) and set (Default) to equal the command to execute when clicked, in this case explorer, e.g. "explorer /root,c:\MyFolder".
Create a set of sub-keys starting at the main key "ShellEx\PropertySheetHandlers\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}" (i.e. [HKEY_CLASSES...ABCD1DE12345}\ShellEx\PropertySheet Handlers\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}])
Create a new sub-key under the main key called "ShellFolder" (i.e. [HKEY_CLASSES...ABCD1DE12345}\ShellFolder]) and create a new Binary value called "Attributes" and set it to "00 00 00 00".
(Optional) To place the folder on the desktop add the following key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\
Explorer\Desktop\NameSpace\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345}]
(Optional) To place the folder in My Computer add the following key:
Explorer\MyComputer\NameSpace\{FD4DF9E0-E3DE-11CE-BFCF-ABCD1DE12345
source :- http://www.pctools.com/guides/registry/detail/73/
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 29-01-2007, 08:16 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
^^great, but siddharth, how can a folder locked with Folder lock made breakable??
I connected my HD as slave in my friend's Computer,and the locked folder was not detected there too.
Nokia N86 8MP
Old 29-01-2007, 08:33 PM   #6 (permalink)
Lightbulb Re: Folder undeletable
I connected my HD as slave in my friend's Computer,and the locked folder was detected there too.
I removed folder lock bcoz it is very easy to break.I dont know abt how the locked folder is breaked but my cousin did it.And abt what the folder lock says that it is safe to keep files in the folder provided by it my bro(currently in 4th class) found this trick accidently last year.The locker which it gives us is a hiiden folder in the directory and it can be accessed without a password.
Visit now ;)
Old 29-01-2007, 08:44 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
@Siddharth, I edited my previous post. What I meant was the hidden folder was not detected when connected as Secondary..
Nokia N86 8MP
Old 29-01-2007, 08:50 PM   #8 (permalink)
anandk's Avatar
nice find siddharta.
wud have been happier if u'd posted the source too ! http://www.pctools.com/guides/registry/detail/73/
am gonna rep u, nevertheless !
Microsoft® MVP
anandk is offline
Old 29-01-2007, 08:57 PM   #9 (permalink)
Thanks for ur reputation i got 12 points .
And thanks for reminding abt the source i hav edited
Visit now ;)
- by gforz
