Old 29-01-2007, 04:33 PM   #1 (permalink)
Chetan1991's Avatar
Angry Low file transfer rate
I have 56Kbps Modem connection.But whenever I connect to the net,message appeares"aaa"(name of ISP)"is now connected at 52Kbps"
While downloading a file transfer rate is initiaLLY 20Kbps and gradually drops to about 3Kbps.I'm frustated .Why this happens?What is the solution??
Chetan1991 is offline
Old 29-01-2007, 05:21 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Low file transfer rate
56kBps is the max conn speed of ur modem.... it doesnt mean that u ll get that speed always... btw wich ISP u using... call ur CC..
Pathik is offline
Old 29-01-2007, 05:27 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
its normal. depending on ur line conditions the speeds may vary. if u can connect to ur isp @ 52kbps. its quite good. very well for that matter. the sustained speed is a bit low. ideally u should get about 7-8kBps (56kbps/8bits) practically atleast 5kBps. check for line disturabances.
infra_red_dude is offline
Old 29-01-2007, 08:35 PM   #4 (permalink)
U can hv ur speed checked by the following sites:-
http://reviews.cnet.com/7004-7254_7-0.html
http://www.2wire.com/bandwidth/initialmeter.php
http://us.mcafee.com/root/speedometer/default.asp
http://www.bandwidthplace.com/speedtest/
http://www.speakeasy.net/speedtest/
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 29-01-2007, 09:08 PM   #5 (permalink)
::cyborg::'s Avatar
well chetan u can tweak ur modem and connection settings by using software like internet booster just google for it
:)) - KEEP SMILING
::cyborg:: is offline
Old 29-01-2007, 09:10 PM   #6 (permalink)
Tech Geek's Avatar
Internet Boosters are useless
They don't boost the speed at all
Tech Geek is offline
Old 29-01-2007, 10:32 PM   #7 (permalink)
Google Bot
Pathik's Avatar
yup they never worked for me too...
Pathik is offline
Old 30-01-2007, 04:26 PM   #8 (permalink)
Chetan1991's Avatar
Actually yes! I also had Turbo Internet Booster which was nearly useless.
Old 31-01-2007, 05:58 PM   #9 (permalink)
Even I get the same speed on BSNL dailup (Netone) I even get the speed in BYTES sometimes
vinith98 is offline
Old 31-01-2007, 07:43 PM   #10 (permalink)
Chetan1991's Avatar
Oh!very sad.more replies are expected.pls help
- by gforz
