Old 27-01-2007, 11:26 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default my pc is hanging
well as i hv earlier also posted abt my monitor going blank problem my pc has started hanging frequently also .... generally happens wen i use apps like azureus and lime wire .... never happened in the past 2 years ... and now suddenly no error no nothing and pc just hangs or starts going blank ..... k hua bhai mare pc ko???
http://beingmanan.com
iMav is offline
Old 27-01-2007, 11:27 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: my pc is hanging
Is it only with p2p s/w's??
Scan ur comp with anti virus in safe mode too..and check ur HDD with scan disk
wizrulz is offline
Old 27-01-2007, 11:30 PM   #3 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Tera time bahut kharaab hai... recently monitor mazaak kar raha tha... abhi pc!
Didja check out in Ctrl+Alt+Del -> Processes Tab, which process is utilizing full CPU (max CPU)?
koolbluez is offline
Old 28-01-2007, 10:13 AM   #4 (permalink)
iMav's Avatar
everything seems to be fine .... system idle process has max CPU .... scan avast using updated scanned it thrice came up with nothing .... and kool bluez sahi bola time bahut kharab hai .... monitor aur pc dono tag team mein meri maar rahe hain
not only p2p ... limewire, azureus, wmp11 or any video ..... iv noticed tht mostly during these apps my pc starts behaving rudely ....
iMav is offline
Old 28-01-2007, 11:47 AM   #5 (permalink)
String Phreak
mediator's Avatar
May be a RAM problem! Neways, before doing anything, I strictly advice to clean ur PC's internels with a vaccum cleaner and dry cloth. I saved myself from going to Nehru place a dozen times like this!
mediator is offline
Old 28-01-2007, 11:48 AM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
when u feel things r not going ur way...its better to start form begining... ..
so start...remove all parts....clean ur pc ....format ur drive...atleast the C:.....and start installing all s/w agian...
wizrulz is offline
Old 28-01-2007, 11:51 AM   #7 (permalink)
iMav's Avatar
well formatting is something i dont wanna do ... coz theres so much installed in this machine tht i myself dont know what all i hav put in the past 2 yrs
secondly the cleaning has been done .... a lot of dust did come out and i thought the problem will be solved but tht wasnt the case
iMav is offline
Old 28-01-2007, 11:59 AM   #8 (permalink)
The Unknown's Avatar
Problem started after/before cleaning?
KDE on ArchLinux
The Unknown is offline
Old 28-01-2007, 04:01 PM   #9 (permalink)
iMav's Avatar
before cleaning and another thing .... today after i closed wmp11 it hung again .... i dont understand ... lime wire, azureus, video players ... i dont mind fromatting but if the problem persists then its gonna sok bad ... so i wanna know the possibilities .... hardware or software????
iMav is offline
Old 28-01-2007, 04:51 PM   #10 (permalink)
String Phreak
mediator's Avatar
U must try some other RAM first before formatting. Borrow from ur friends!
Neways u may try a live "knoppix CD", if things go OK with it then RAM is fine. Its probably windows fault then.
mediator is offline
Old 28-01-2007, 05:23 PM   #11 (permalink)
iMav's Avatar
^^wont ubuntu help me out ... coz i hv ubuntu but not knoppix
iMav is offline
Old 29-01-2007, 09:08 AM   #12 (permalink)
I Always Prefer 1080p
techtronic's Avatar
No Problem
Run Ubuntu as a Live CD and check out the performance
techtronic is offline
Old 29-01-2007, 11:27 AM   #13 (permalink)
String Phreak
mediator's Avatar
Yea, u can run any live linux cd.
mediator is offline
Old 30-01-2007, 06:32 PM   #14 (permalink)
iMav's Avatar
update:
i tried ubuntu and it worked fine .... but then wen i restarted ... the system hung again before the login screen wen booted into xp (not the first time this has happened) .... so hard booted again and came across this error again
BCCode : 1000007f BCP1 : 00000008 BCP2 : 80042000 BCP3 : 00000000
BCP4 : 00000000 OSVer : 5_1_2600 SP : 2_0 Product : 256_1
C:\DOCUME~1\Manan\LOCALS~1\Temp\WER42a6.dir00\Mini 013007-02.dmp
C:\DOCUME~1\Manan\LOCALS~1\Temp\WER42a6.dir00\sysd ata.xml
iMav is offline
- by gforz
