yes its a spyware attack. and ur
browser/home/search pages have been hijacked.
first run adaware, avg, spybot (or any 2 good anti-spys) in SAFE MODE.
then use 'ccleaner' to clear up residual pc junk.
open your ie>intenet options>homepage>change to about
:blank
then
lock your home page.
If the feature is disabled (greyed out), go to Doug Knox's site and download
this script this dougknox script and save this file to your hard drive. Navigate 2 where u saved it n double click d file. d
VB Script file will check 4 d appropriate value & if not found will create it. u will be notified whether d option is enabled or disabled.
2 manually make d change:
open Regedit and go to and change to
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main] "about
:blank"
Home Page Hijacked :
If the Tabs have been removed from Internet Explorer/Tools/Internet Options and/or u receive a restriction warning message, run
Restore All Tabs under Internet Options (kellyskorner tweak no 268 ) It will restore all tabs and lift the restriction.
after u have set to 'about
:blank' using above or internet options now, lock it !
download
this kellyskorner registry tweak and doubleclick/add 2 registry.
u will also check if ur
hosts file has been hijacked.
its located in C:\WINDOWS\system32\drivers\etc
i suggest u download a GOOD hosts file from here
http://www.mvps.org/winhelp2002/hosts.htm
unzip it and place it in the above location. replace ur existing file. dont worry !
read info in this link so that u r also satisfied. then
LOCK ur hosts file.
