Old 26-01-2007, 11:23 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Your Computer Might be at RISK ?????
I am using Windows XP Pro SP2.
Nd I hav turned the automatic updates OFF, but then at evry startup, it shows a msg that ur computer might b at risk and an [color]RED[/color] Icon always present there. How can i remove that?
Manshahia is offline
Old 26-01-2007, 11:29 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Your Computer Might be at RISK ?????
Just set "Security Center" service to "MANUAL" in Services.msc
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 26-01-2007, 11:29 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Simple.
Goto Control panel->Security Center
From the left panel select Change the way security center alerts me.
From here you can uncheck all the options for no popups during startup.
Nokia N86 8MP
Lucky_star is offline
Old 26-01-2007, 11:36 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
do check out if its the windows security center icon. if yes then above method. chances r yes, since u have turned off the auto win updts, the sec centr is reminding u...
else it could be a rogue program ! so reconfirm pls.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-01-2007, 11:43 PM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
Yes its the red balloon one. I think its windows security Icon.
Old 27-01-2007, 12:17 AM   #6 (permalink)
shantanu's Avatar
click on that red baloon and click on change the way security center alerts me and then uncheck all the three
shantanu is offline
Old 27-01-2007, 12:23 AM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
Done. Thnx.
Old 27-01-2007, 01:20 AM   #8 (permalink)
Arsenal_Gunners's Avatar
Nd I hav turned the automatic updates OFF, but then at evry startup, it shows a msg that ur computer might b at risk and an [color=red]RED[/color=red] Icon always present there. How can i remove that?
delete =red in that and watch it get red color
Arsenal_Gunners is online now
Old 27-01-2007, 10:34 AM   #9 (permalink)
Resident Fanatic
Manshahia's Avatar
Nope. No changes.
Old 27-01-2007, 11:19 AM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
its like this [color="red"<] [/color] (remove the < symbols)
btw why do you want to Turn OFF the Updates, you can select "Notify Me but dont automatically download or install them"
this applies if you have Legit XP
ASUS K53SV SX520D + BF3
s18000rpm is online now
- by gforz
