Originally (before 1.65) Flashget gave an option to install either as a "Shareware" or an a "free" Adware. This has changed recently (not sure which exact version). So, try to get an older version, install that and register that - then, try upgrading to the newer version (might work, may not work).
BTW, if you have indeed registered it, you should be able to obtain a 'adware' free installer from them.
