Re: web pg size in Dreamweaver ! ! !
You will have to slice the images. If you show me the .jpg of your PSD file, I will tell you how to slice it.
"How to slice" = not the procedure but the sizes of slices. You can once again pick some tutorial on the procedure for slicing.
After defining your slices, you will have to use "Save for Web" option. It will make a .html file and also separately save each slice as JPG. You can discard the HTML file, but use the JPG files.
I can tell you more only after looking at the design and layout.
