Old 16-01-2005, 05:57 AM   #1 (permalink)
Default Crashing Right Click
Well, I recently reinstalled my windowsXp and after installing all necessary software I got this problem-
Whenever I right clicked a folder it hangs and I have to end explorer.exe in taskmanager and restart the process. Is there a way around it?
I couldn't install any sp packs as it says my version is pirated one! I got the CD from my compaq dealer when I succeeded in killing preformated xp install more that twice in a week!
So, what can I do to save my system from its right click hangouts?
P.S:-It hangs only with folders, not files.
\"Still waters run deep\"
\"I smile in the dark .......\"
Scorpion is offline
Old 16-01-2005, 04:11 PM   #2 (permalink)
sunnydiv
Posts: n/a
my friend had similar problem, after he tried zone alarm
it was like right clikc = reset :roll:
Old 16-01-2005, 04:26 PM   #3 (permalink)
Try booting in safe mode and see if it happens there. If it doesnt then you run msconfig and disable all unnecessary programs from startup. Now see if the problem occurs, if it doesnt, then one of your startup programs is creating trouble. Re-enable one by one until you get the problem. This will help in identifying the culprit.
sailendra is offline
Old 16-01-2005, 06:07 PM   #4 (permalink)
hi,
I disabled all my start up programs and the problem persists. It is present even in safe mode.
Thankyou for your advise, awaiting more tips/clues to solve this.
Scorpion is offline
Old 16-01-2005, 06:33 PM   #5 (permalink)
alib_i's Avatar
Scorpion,
It seems like one of the entries in your Folder's right click menu is corrupted
Your problem is similar to Right Click Crash
But well may be that's not the solution to ur problem
See if THIS TIP or THIS TIP can help or not
It still the problem persists ..
then you may have to delete the corrupted entry by hit-and-trial
Look at this page
and this page
you can try using shell extension managers like
http://www.nirsoft.net/utils/shexview.html
http://demosten.com/shellexman/
alibi
-Metallica
alib_i is offline
Old 16-01-2005, 08:41 PM   #6 (permalink)
Originally Posted by Scorpion
hi,
ok aditya
try these:
http://forum.aumha.org/viewtopic.php?t=7307
http://www.tek-tips.com/faqs.cfm?fid=4163
The first one has several solutions - one of which is already mentioned by alibi. check them out and let us know if its of any help
- by gforz
