Old 24-01-2007, 11:22 PM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Default About C functions clrscr, delay. Cannot be found?
Hi
I have a question. I have been using turboc C for some time now. I heard that DevCPP is better, so now I am using it on Windows. And on linux, I am using Anjuta that comes with opensuse 10.2
Now the problem is that, the function clrscr, used to clear the screen is not avalable in both of them. And the function delay, used to delay the processing (time.h) is also not avalable. So are there any alternate functions that can be used to do these/ perform these operations?
Aditya
--- Console Junkie
aditya.shevade is offline
Old 24-01-2007, 11:51 PM   #2 (permalink)
Fresh Stock Since 2005
Default Re: About C functions clrscr, delay. Cannot be found?
Originally Posted by aditya.shevade
Hi
Aditya
I'm planning to leave TC and go to devC++ too....
I think copying the respective header files from TC to devC++ include folder with a different name (eg: stdio1.h for stdio.h) and including that file (stdio1.h) using #include might help....
http://www.khattam.info
khattam_ is offline
Old 24-01-2007, 11:55 PM   #3 (permalink)
Console Junkie
Yes it might be possible, but I think there must be some other way, because in the case what you have suggested, what if gcc or mingw does not support that? I have no idea if it will work or not, but let me try.
Aditya
--- Console Junkie
Old 24-01-2007, 11:57 PM   #4 (permalink)
MysticDews's Avatar
AFAIK delay() is defined in dos.h (talkin bout Turbo Cpp)
Also try to check the settings in Options>>Directories..Set it to the right path if it is not pointing to the right path (where ur .h files are located)..
May be that should help..
Or if it duznt, then reinstall it..
________________________________________________
In love with my Mac 
MysticDews is offline
Old 25-01-2007, 12:14 AM   #5 (permalink)
Console Junkie
Ahh.. I am sorry, My mistake. It is in dos.h. But sill devcpp says that delay should be defined before using it. And you do not have dos.h file in anjuta (linux). So any other ideas?
And about clrscr, all the header files get included. It's just that the function prototype is not avalable.
Aditya
--- Console Junkie
Old 25-01-2007, 04:16 PM   #6 (permalink)
tuxfan's Avatar
Have a look at http://www.mailnspace.com/download/c.source/
These are some old C functions and .h files made by me. It also includes a clrscr() substitute It was all under DOS. But you can see the logic and make your own ones for Windows. There is one sample calendar application that used these functions and header files
tuxfan is offline
Old 25-01-2007, 09:45 PM   #7 (permalink)
Thor's Avatar
its true , i hv used DevCpp but they will give error if u use clrscr() !
I hv faced this problem earlier and the bloodshed.net FAQ is of no help too.
So I checked this http://www14.brinkster.com/aditsu/de...faq.html#conio
`clrscr' undeclared (first use this function)
[Linker error] undefined reference to `clrscr'
Why can't I use conio.h functions like clrscr, gotoxy etc?
First you should note that conio.h is a Borland extension, NOT a standard header, so Dev-C++ and MinGW are in no way required to support it. The MinGW included with Dev-C++ 4.9.9.1 comes with a very reduced version of conio.h (no clrscr, gotoxy, etc); if you need more then you can use the native Windows console functions.
I also provide and maintain an updated version of conio (and also winbgim) at http://www14.brinkster.com/aditsu/console/; that may be what you are looking for.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
- by gforz
