Old 15-01-2005, 09:32 PM   #1 (permalink)
Default No File Option
Recently i noticed that my file option is missing from the menu bar in almost in explorer. Plz help, i dont want to format my system.
Shwetanshu Srivastava
shwetanshu is offline
Old 15-01-2005, 11:07 PM   #2 (permalink)
update ur OS...........
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
imprince is offline
Old 16-01-2005, 12:41 PM   #3 (permalink)
Default Found Solution By Me
i found solution by myself, thought there must be something wrong in the regisrty, so opened it searched it for 3.5 hrs and found the solution. Here it is
HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\Explorer
Set the DWORD "NoFileMenu" to 0 and my problem was solved.
Well thanx to all, who tried to find the solution
Old 16-01-2005, 02:10 PM   #4 (permalink)
Default Re: Found Solution By Me
it is said that "self help is best help"
but i entered in to the post thinking of saying i think the prob is with registry but u have solved it ureself.
but still how does that change occured.
normally, some adware or some programs makes changes in registry (i mean unathorised changes)..so i think you should analyse it and take a good software which stops or ask you before changes are made in registry.
who knows next time your whole drives may be missing...
be who u r :
Saharika is offline
- by gforz
