Old 22-01-2007, 10:17 PM   #1 (permalink)
Lightbulb Plz solve these three ?ns
Hello frnds I hav 3 ? to ask to u:-
a>How to change the extension of a file in dos - mode
b>My view button has been diabled in the explorer how can i enable it .I searched for its registry entry but as i am a fool i didnt got it.Plz tell me
c>I use i.e 6.Since its my pc therefore i click remember me on this pc .But now in any of the sites it doesnt remeber me and i can delete the exsisting ids.
THanks in advance
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 22-01-2007, 10:28 PM   #2 (permalink)
::cyborg::'s Avatar
Default Re: Plz solve these three ?ns
dont know ur b part but for
a) command is ren c:\1.doc 1.txt (assuming u r using a doc file)
c) use mozilla firefox(will solve ur purpose
and i think u hve used all the smileys
:)) - KEEP SMILING
::cyborg:: is offline
Old 22-01-2007, 10:32 PM   #3 (permalink)
kumarmohit's Avatar
For you first question u must either know the extension of the file u want to rename or not.
Now Case 1, u know the extension (say txt to be changed to htm)
ren 1.txt 1.htm
Case 2 U dont know the extension but only the file name say 1 then
ren 1.* 1.htm
kumarmohit is offline
Old 23-01-2007, 12:05 AM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
2.) Right-click on toolbar and select "Customize", now u can add "View" button in toolbar.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-01-2007, 12:12 AM   #5 (permalink)
Arsenal_Gunners's Avatar
Originally Posted by siddharth_2463107
u:-
You are not a fool because you searched the whole registry for this thing(not many people can do)
And nice smilie show.
Arsenal_Gunners is online now
Old 23-01-2007, 02:31 PM   #6 (permalink)
Lightbulb Re: Plz solve these three ?ns
I mean the nothing happens when i click on the button
__________
Thanks frnds
Will the ren command chande .dll to .dl_ also
Thanks in advance
__________
Thanks frnds
Will the ren command change .dll file to .dl_ file also
Thanks in advance
Plz solve my c p[art also
Visit now ;)
Last edited by Siddharth Maheshwari; 23-01-2007 at 02:31 PM. Reason: Automerged Doublepost
Old 23-01-2007, 02:34 PM   #7 (permalink)
what does that mean?
Old 23-01-2007, 03:28 PM   #8 (permalink)
Microsoft MVP
@Siddharth
Did u apply my "Enable View Menu on Desktop" hack?
Old 23-01-2007, 05:29 PM   #9 (permalink)
@ vishal
the method u gave me to solve the problem "folder option " in tools ,
is that pages ok for sidharth.if yes pl give him
suraj is offline
Old 23-01-2007, 05:41 PM   #10 (permalink)
@Siddharth
Ya after that only the view button has got disabled
Visit now ;)
Old 23-01-2007, 05:48 PM   #11 (permalink)
reapply it then.
Old 23-01-2007, 07:30 PM   #12 (permalink)
Microsoft MVP
Thats why I asked about it.
That hack always causes this problem, I also mentioned it in that thread.
Whenever we apply that hack, the "View" buton in toolbar stops working!
Old 23-01-2007, 08:07 PM   #13 (permalink)
Oh thanks for telling I will find the hack to overvcome this problem
Thanks for replying
Visit now ;)
Old 24-01-2007, 02:34 PM   #14 (permalink)
Originally Posted by kenshin1988
dl_ is compressed dll file(supposing it be from i386 folder)..Use the expand command to extract it...
use the foll command
expand abc.dl_ abc.dll {expand [source] [destination]}
BTW dl_ files can be opened with winrar...
I wnat to ask will ren command change .dll to .dl_ also
Visit now ;)
Old 24-01-2007, 05:26 PM   #15 (permalink)
With ren command u can change the extension for a file...but can't change its type.(obviously..)....The dl_ files which are in i386 folder of winXP setup are basically zip files containing the dll....eg..hal.dl_ is actually a zipped file containing hal.dll...
So Obviously u cannot expect a zip file to get converted to a dll just by renaming it...U have to extract it using expand command..
to change the dll files to dl_ u have to compress the file and then rename the file to .dl_..
That means I can change a .zip file to .dl_ file
Also plz tell me the dos command to change the extension of multiple files at a time
I have nearly 1000icons in a folder i want to change them in .bmp plz tell me the command
Visit now ;)
Old 24-01-2007, 05:41 PM   #16 (permalink)
Microsoft MVP
^^Buddy! U can't change a filetype using DOS commands.
When U'll rename the file "a.ico" to "a.bmp", it'll not convert the ico file into BMP file. It'll only rename the file but it'll remain an ico file.
U can use various softwares to change filetypes.
And regarding to dl_ files, these are compressed dll files, to create these compressed files u can use following command:
makecab file_name
for example:
makecab shell32.dll
and to extract actual file from these compressed file use following command:
expand old_file_name new_file_name
example:
expand shell32.dl_ shell32.dll
Old 24-01-2007, 05:47 PM   #17 (permalink)
dude will u tell me some of the freeware softwares for the above thing and plz tell how u know this much
__________
And one more thing can u tell me when we change the background of a window why we use [{BE098140-A513-11D0-A3A4-00C04FD706EC}]
for example
iconarea_image=C:\WINDOWS\Web\Wallpaper\VistaBliss .jpg
iconarea_text=0x00FFFFFF
Thanks in advance
Visit now ;)
Last edited by Siddharth Maheshwari; 24-01-2007 at 05:47 PM. Reason: Automerged Doublepost
Old 24-01-2007, 06:00 PM   #18 (permalink)
Microsoft MVP
1.) Open the ico file in mspaint and then Save as the file to BMP file.
2.) Knowledge comes with experience.
3.) Coz this string is hardcoded into windows shell and used for "Folder Settings". Many such strings are used for other tasks, like:
{8BEBB290-52D0-11d0-B7F4-00C04FD706EC} for Thumbnails View.
Old 24-01-2007, 06:24 PM   #19 (permalink)
Beware of the innocent
ilugd's Avatar
if you have a lot of ico files, irfanview's batch convert would be a better bet, wouldn't it be, vishal?
Life is too short. Have fun.
ilugd is offline
Old 24-01-2007, 06:28 PM   #20 (permalink)
Microsoft MVP
^^ Indeed.
Old 24-01-2007, 07:29 PM   #21 (permalink)
In which dll file I will find these type of code
Plz dont mind
Visit now ;)
Old 24-01-2007, 07:32 PM   #22 (permalink)
Microsoft MVP
All these strings are placed in "Shell32.dll" file.
But don't even think about playing with them otherwise u'll get a non-bootable system.
Old 24-01-2007, 08:16 PM   #23 (permalink)
No i just want to know abt them r they in string section
Visit now ;)
Old 24-01-2007, 08:24 PM   #24 (permalink)
Microsoft MVP
In REGINST section.
