Old 15-01-2005, 02:12 PM   #1 (permalink)
Default writer woes
my Verbatim CD-Writer is no longer burning CDs! When i try to burn a CD using Nero Burning ROM Ultra 6, i get a msg. saying the CD is burnt successfully, but it is not getting burnt at all! I tried a s/w (CDBurner XP Pro 3) included in Digit Jan 2005 which gives the foll. error: "A flaw exists in the Power Calibration Area(1048)..." Help GUYS!
my writer is 14 months old. i am using an athlon XP 2400+, 256 DDR, Win XP.
P.S. I tried changing the make of the CD-r but to no avail
sriniharichu13 is offline
Old 15-01-2005, 09:43 PM   #2 (permalink)
Default Re: writer woes
most of the time its the cd-r fault....
since warranty over, remove the drive and clean the lens
Hmmm...do i need one?
sunmysore is offline
Old 18-01-2005, 06:54 AM   #3 (permalink)
"Sometimes" it is a software problem, but you have to reinstall everything from scratch to fix it. IF you can try the drive out on another machine first. It it does the same thing then it could be a hardware problem. Like maybe bad cd's or dirty head.
AlienTech is offline
