my case makes a humming noise...its getting louder and louder. i have placed cloth underneath but that aint helping much. i think its because of the fan. how do i fix it??
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
SMPS fan is one which is in ur power supply ....open one side of ur cabinet and check frm where the noise is emerging....also d/l speed fan to control fan speed ....if its not smps fan...if it is ..u have to clean smps fan
Remove connection of all other fans and start the machine...in this way you can easily check whether the SMPS fan is the culprit. If it is not, simply reconnect other fans one by one and repeat.
