Old 22-01-2007, 01:50 PM   #1 (permalink)
The Devil
blackpearl's Avatar
Question Is defragmention any good?
Most people regularly defragment their hard disk, but I don't. People say that it increases performance and life of the hard disk. But in my opinion it does more harm than good.
Consider what benefit you get by defragmenting - just a few milliseconds gain in access time. But in order to make your hard disk's access time a fraction of a second lower you make your hard disk undergo massive disk thrashing for hours!! Some people state that defragmenting lowers disk thrashing by making the file available at one place instead of many places. True, but thats only minor thrashing, for just a couple of seconds or even less than a second, depending upon the size of the file. But to save the hard disk from a few seconds of daily thrashing you make your hard disk go through hours of thrashing - read-move-write;read-move-write .... non stop for hours. Isn't that going to do more harm to your hard disk? Isn't this exessive work out lower the life of your hard disk? Considering what you get in return, a barely noticeable difference in access time, do you think its wise to defragment your hard disk? Maybe 3 times a year would be OK, but certainly not monthly.
I did some search and found some articles that says that defragmenting does not help to improve performance. The only use, if any, of defragmenting is that it helps recover data in the event of a disk crash. None of them said about the disk thrashing part though, thats completely my idea.
Originally Posted by http://www.techbuilder.org/recipes/59201471
While it was true that defragmenting helped older PCs, it no longer applies. Today we have 7200-RPM (rotations per minute) hard-disk drives with improved seek and latency times; many also contain an 8-MB cache buffer. Let's not forget Windows XP's ultra-efficient NTFS (NT File System). For PCs, servers, and workstations equipped with these innovations, defragmenting no longer makes much improvement, if any, to system performance.
Originally Posted by http://www.pcworld.com/article/id,86934-page,8/article.html
The PC World Test Center's tests reveal that defraggers don't actually improve performance. And Steve Gibson, president of PC consulting firm Gibson Research Corporation, confirmed our findings.
Nevertheless, regular defragging is still a good idea to aid disaster recovery. The more fragmented the files on your drive are, the more likely a disk error is to destroy them.
So what is your opinion?
blackpearl is offline
Old 22-01-2007, 01:57 PM   #2 (permalink)
Default Re: Is defragmention any good?
If your files are defragmented, whenever you have to access a particular file, the computer will have to read from various parts of the disk. During this process, the computer will have to spin the disk back and forth. This will lead to reduced life of the hard disk. By defragging once in a while, you will make sure this process will be reduced. In NTFS partitions, files are less likely to be fragmented, and so, you may need to defragment it less. Basically, the more often you need to access the files in a particular partition, it is healthier to defragment the drive more often.
Arun
sakumar79 is offline
Old 22-01-2007, 03:40 PM   #3 (permalink)
Once in Month or 2 months is OK
Stick is offline
Old 22-01-2007, 03:41 PM   #4 (permalink)
Cool G5's Avatar
Lightbulb Re: Is defragmention any good?
If u are worried about the time taken for defragging.Use Auslogic disk defrag.
http://www.softpedia.com/get/System/...k-Defrag.shtml
Cool G5 is offline
Old 22-01-2007, 06:32 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
i had come across this much earlier, and am inclined to agree with these findings; nevertheless, out of habit, i guess, and bcoz it is there i defrag my disk once every 3 mnths or so.
thanx for such a nice post
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-01-2007, 06:34 PM   #6 (permalink)
ashisharya's Avatar
auslogics defrag is da best defrager
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 22-01-2007, 06:57 PM   #7 (permalink)
The Devil
blackpearl's Avatar
Actually I defrag too, not out of habit though. I defrag the C drive using O&O Defrag with the setting "Complete/Name". What it does is that it arranges the files alphabetically which helps Windows boot quickly, and it really works. Other than that I rarely defrag. Sometimes after a few months I defrag the drive where I install my s/w or games.
Old 22-01-2007, 07:45 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
i defrag once in 2-3 months, for me usually the game files get defragmented, not mainly because of gaming, but coz i mess with them
when the bigger files (800MB & bigger) get fragmented, i use a less time consuming method, just "cut-paste" it on other partition & then reverse-> "cut-paste" it to original location. this way it gets copied as a contiguus file
btw i use DiskTrix Ultimate Defragger, its does the defragmenting really Fast.
__
s18000rpm is offline
Old 22-01-2007, 08:30 PM   #9 (permalink)
EagerBeaver's Avatar
How to defrag Registry ??????????
FREEDOM ROCKZ...ATTITUDE RULZ
EagerBeaver is offline
Old 22-01-2007, 08:33 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
i use TuneUp Utilities 2007 for registry Defragmentation.
__
Old 22-01-2007, 08:35 PM   #11 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
very useful... provided ur drive was very fragmented before doin it
koolbluez is offline
Old 22-01-2007, 09:54 PM   #12 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Hehe.. I too hate defragging.. That's why i use Linux! No need for defragging at all!
kalpik is offline
Old 22-01-2007, 10:07 PM   #13 (permalink)
t3h g04t
teknoPhobia's Avatar
I have news for you... it doesn't, windows writes to the first available sector/s, so unless you have that much contigous free space at the beginning of the partition, youre just wasting time. Of Course, you could just copy everything and then move them back, but youd require that much free space on another partion and so on, and I fail to understand the concern about the time taken, for me defragging a 60GB partition which is 60% or more full takes about an hour
technologically challenged.
teknoPhobia is offline
Old 22-01-2007, 10:12 PM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
i dunno about the sectors, but this method works for me, every time.
my game partition is right now has only 15% space. (25GB partition), & yesterday i did the cut-paste thing for a 900MB GTA file, & it worked
__
Old 25-01-2007, 02:46 PM   #15 (permalink)
Shasanka_Gogoi's Avatar
If u have a large no. of huge files and have not defragmented for many months than your hard disk will surely undergo massive disk thrashing for hours. But make it a routine to defragment once a week using O & O(trust me its the best) and u would surely notice the performance gain over time.
Shasanka_Gogoi is offline
Old 25-01-2007, 09:20 PM   #16 (permalink)
The Devil
blackpearl's Avatar
There is one program that defragments on the fly. Haven't tried it though, but if it works it would save a lot of time and will be very effective.
http://dirms.com/
Old 25-01-2007, 09:45 PM   #17 (permalink)
Fresh Stock Since 2005
Ashampoo Magical Defrag defragments your HD when CPU is idle in background..... it is a very good defragmentor...
http://www.khattam.info
khattam_ is offline
Old 26-01-2007, 12:39 PM   #18 (permalink)
Google Bot
Pathik's Avatar
i defrag once evy six months...
Pathik is offline
Old 27-01-2007, 04:26 AM   #19 (permalink)
 Macboy
goobimama's Avatar
Defrag is good when there is less RAM in the system. It speeds up the virtual memory performance. But if there is ample amounts of RAM, say above a gig, then I find it to be less of a performance increase...
I don't defrag.
I'm like a bird...
goobimama is offline
Old 27-01-2007, 07:15 AM   #20 (permalink)
Defragmentation is not only about improving performance... It also helps to improve hard-disk life...
Arun
Old 27-01-2007, 09:40 AM   #21 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Yes... I agree with Sakumar here.... defrag also enhances life of the HD... y... because lesser in-drive motions!!!
Read this
But over-defraggin can actually reduce the life too
Old 27-01-2007, 03:43 PM   #22 (permalink)
::cyborg::'s Avatar
use a ntfs partition it takes very less time to defragment
- KEEP SMILING
::cyborg:: is offline
Old 27-01-2007, 05:38 PM   #23 (permalink)
That is true, NTFS partitions are less susceptible for fragmentation than FAT partitions... But if you frequently write data to the partition, in about 6 months to 1 year, you will have serious fragmentation. This is based on experience (partition with programs didnt get fragmented much after 6months, but partition with data got very fragmented and took a while to defrag...)
Arun
Old 27-01-2007, 06:38 PM   #24 (permalink)
Chetan1991's Avatar
Well who orders you to defrag it every week?
just do it once in 6 months or when you uninstall a huge program and install another one.
Chetan1991 is offline
Old 27-01-2007, 07:14 PM   #25 (permalink)
The Unknown's Avatar
Smile Re: Is defragmention any good?
USE pagedefrag. It will defragment your pagefile and registry before Windows starts.
KDE on ArchLinux
The Unknown is offline
Old 29-01-2007, 04:06 PM   #26 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
auslogics defrag is good .........
default defrag takes ages 2 complete & u r right (me 2 realised NOW) ..... defrag ur hdd 2 get JUST few secs of access time 2 ur files ........ & in turn hdd & pc gets heated 2 .........
i used 2 defrag after 5months ........
ax3 is offline
Old 30-01-2007, 12:53 AM   #27 (permalink)
rajasekharan's Avatar
I use perfect disk 8 and defrag once in two weeks . No probs yet .
Make a day good , and another day good , and another ...a happy lad is "born" from you
rajasekharan is offline
Old 30-01-2007, 09:01 AM   #28 (permalink)
Mr. S Nova
supernova's Avatar
Even I defrag once in 3-4 months.. and being NTFS it doesn't take that long what it used to be in Win 98/Me days...
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 30-01-2007, 12:56 PM   #29 (permalink)
GaurishSharma.com
gary4gar's Avatar
even there are tools available for defrag available in linux too
gary4gar is offline
Old 09-02-2007, 06:57 PM   #30 (permalink)
9437077259
go4saket's Avatar
Defragging once in a few months is fine for me...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
