Old 15-01-2005, 09:07 AM   #1 (permalink)
Default MS ACCESS WITH VB6 ENTERPRISE EDITION
Helo, I am not able to use VB6 as front end for MS Access 2000 & above. But it is accepting MS Access 97 for data source. Pl tell me what is the problem & give me solutions also.. My PC Pen IV with 256MB RAM.
AHHNPANTH is offline
Old 15-01-2005, 01:21 PM   #2 (permalink)
Yes! Even I faced the problem
after creating db in Access 2000 convert it to Access 97 then it works!
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 15-01-2005, 04:28 PM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
You need to access the database through ADO and not DAO for databases newer than Acess 97 ...
See these links for more ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 15-01-2005, 07:43 PM   #4 (permalink)
Sir, the solution of changing MS Access 2000 to 97 does not serve the purpose, as edting in 97 will again give raise a problem. Pl suggest me another way.
Panth
Old 15-01-2005, 10:24 PM   #5 (permalink)
are u using ADO or DAO?
Old 17-01-2005, 01:28 PM   #6 (permalink)
tuxfan's Avatar
I disagree. I have used VB6 with Access 2000 database using DAO. So that is not the problem here.
tuxfan is offline
