Old 21-01-2007, 12:44 AM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default how one can b tracked by IP Address
I hav heard that one can b traced by IP address i.e we can find frm where he sent those email nd all that.
How can this b done?
Manshahia is offline
Old 21-01-2007, 01:07 AM   #2 (permalink)
pro
pro's Avatar
Lightbulb Re: how one can b tracked by IP Address
your service provider assigns a static IP address to your connection which does'nt change. you are also given dynamic IP address for surfing which gets assigned to a new user once you log off. static IP tracks you down. if you use annonymous surfing sites like annonymouse.com , you surf VIA their sever and as far as i know you can't be tracked down.
by the way. I have read in times of india bombay long ago that militants in kashmir vally use "dead letter" communications. they just distribute a common email id with passwords among themselves and save EACH communication in the DRAFT folder. by this way no mail is sent.... SO NO QUESCTION OF TRACKING.....
everything starts with a zero and ends in one.
pro is offline
Old 21-01-2007, 01:12 AM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Re: how one can b tracked by IP Address
Added to rep
Old 21-01-2007, 01:28 AM   #4 (permalink)
24online's Avatar
Arrow Re: how one can b tracked by IP Address
also ISP has track records of sites u surfed... and also for cybercafe... if user use annonymous site... they can ask annonymous site, to give details... b/s they send cookies to ur pc..
and they have firewall and log system also...
Best firewall is Jetico .. small and free. all protocols can be see...
**#(o)#**
24online is offline
Old 23-01-2007, 02:31 AM   #5 (permalink)
pro
pro's Avatar
Post Re: how one can b tracked by IP Address
if we delete cookies then.?
bty very few progress can be made if server is stationed outside India... time consuming.... delete log of firewall if you can....
also about firewall of ISP that i don't know but this method is good upto a certain point
but you always can't say.. big brother may be watching....
pro is offline
Old 23-01-2007, 09:34 AM   #6 (permalink)
whoopy_whale's Avatar
Simple,and good idea!
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 25-01-2007, 01:02 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
gud info .......... thanx
ax3 is offline
Old 25-01-2007, 01:12 PM   #8 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Check this
http://www.dnsstuff.com/tools/ipall.ch?ip=59.244.1.117
And thats just a Random IP i put in
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-01-2007, 02:04 PM   #9 (permalink)
hailgautam's Avatar
Go to this site, if you know a IP address the site will tell you the location of the system. Some times it gives wrong info though. Many times it keep saying that my system is in Ahemedabad, while it is you know where!!
http://www.geobytes.com/IpLocator.htm?GetLocation
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
