Old 20-01-2007, 10:59 PM   #1 (permalink)
bukaida's Avatar
Default Help, Everything seems lost.
I have used partition magic 8 for repartioning my c drive. I have 4 partitions.After the successful completion of the operation, nothing happened to C drive and the other partions become in accessable.Whenever I click on any partition it gives a prompt to format.
But inside partition magic, it correctly shows the old volume names and the amount of information contained in the disk. Is there any way to recover them or everything has gone? I have used a backup software named restoration which shows the files with $ symbols but couldnot retrieve any of them. BTW I have not done anything to those partion till now hoping to recover the datas. I donot know whether this is the correct forum for this question but my brain is simply not working after this disaster.Pleeeeeeeese help.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 20-01-2007, 11:28 PM   #2 (permalink)
Default Re: Help, Everything seems lost.
Seems that your partition table is messed up somehow.
Try Puppylinux liveCD and see if it can read them. Try other liveLINux too ..
Ricky is offline
Old 21-01-2007, 12:38 AM   #3 (permalink)
Google Bot
Pathik's Avatar
format the partns usin part magic again
Pathik is offline
Old 21-01-2007, 10:36 AM   #4 (permalink)
bukaida's Avatar
Trying different options in partition magic did not help.
bukaida is offline
Old 21-01-2007, 11:55 AM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
go the old school way .... boot using secondary bootable media such a win98 floppy or cd .... format ur partitions
http://beingmanan.com
iMav is offline
Old 21-01-2007, 03:33 PM   #6 (permalink)
He said he need his data ..
So formatting is not great idea..
Have you tried LInux LIVE cds yet ?
Ricky is offline
Old 21-01-2007, 03:39 PM   #7 (permalink)
iMav's Avatar
^^ i am saying format the new disk partitions
iMav is offline
Old 21-01-2007, 07:00 PM   #8 (permalink)
bukaida's Avatar
Smile Re: Help, Everything seems lost.
@Ricky: man, I donot know how to thank you.Your solution worked like a piece of cake. I had DSL from old digit cd and could copy the files in a new harddisk easily by mounting both of them.Only thing is ,it is taking too much time but again it is ok.
And yes, formatting the partition was not my issue.I wanted to save my data.
Thank you very much again.
bukaida is offline
Old 22-01-2007, 01:57 AM   #9 (permalink)
I am glad it worked for u
Ricky is offline
