WHen i start my computer, My computer automatically shows up even the icons at bottom right corner come after that.
I hav also cheked startup in start menu, but cudnt find anything.
Wat is the problem?
In the left navigation pane, Open HKeyLocalMachine > Software > Microsoft > Windows > CurrentVersion > Run
See if any startup entry for My Computer is there
Same goes for HKeyCurrentUser > Software > Microsoft > Windows > CurrentVersion > Run
Most probably there is a shortcut to My Computer in your Startup folder.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
