Old 20-01-2007, 06:26 PM   #1 (permalink)
SE><IE
Posts: n/a
Default Setting up RAID-0
I'm currently on 80GB IDE but soon I'll be getting two 250GB SATA-II drives.
I want to connect them in RAID-0 configuration.
I have some questions to ask:
1. Can my current IDE drive also be added to the RAID-0 group? I suppose not because of different interface (IDE Vs SATA), different capacity and of course difference in speed.
2. In case I can't add this 80 GB HDD to the array, can it be used as JBOD? i.e., is it possible that two SATA drives work in RAID-0 array and this one just like the current form.
3. How exactly do I setup RAID-0. My motherboard's manual has given a tutorial on the same but they are asking for RAID drivers. Now My floppy drive doesn't work(hell, floppy drives must die !!) so how do I put drivers.
4. I know about setting up soft RAID though disk-management. But then again, I don't wanna risk things.
I suppose if someone of you must be having a first-hand experience of setting up an RAID array. Please help me out.
Old 20-01-2007, 06:53 PM   #2 (permalink)
Default Re: Setting up RAID-0
1. No.
2. Yes, you can use the IDE HDD as a separate drive, just the way it's currently running.
3. You could try letting Windows setup load up generic RAID drivers and see if that works otherwise you need to get a floppy drive.
drvarunmehta is offline
Old 20-01-2007, 10:16 PM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
I hope this helps
http://www.hardwaresecrets.com/article/393
techtronic is offline
Old 21-01-2007, 04:58 PM   #4 (permalink)
SE><IE
Posts: n/a
Thanks techtronic
Old 21-01-2007, 11:58 PM   #5 (permalink)
techtronic's Avatar
Always Welcome Buddy
Old 15-02-2007, 09:16 PM   #6 (permalink)
Does RAID 0 helps in speeding up a multitasking machine engaged in graphic applications?
My Asus P5B-dlx has RAID support, but I don't know if its called hardware RAID or software RAID.
ranjan2001 is offline
Old 15-02-2007, 09:42 PM   #7 (permalink)
SE><IE
Posts: n/a
http://en.wikipedia.org/wiki/RAID
http://en.wikipedia.org/wiki/Standard_RAID_levels
Here you go
