20-01-2007, 10:33 PM
Resident Fanatic
How to keep the systm Cool
I hav only two fans in my PC
one at CPU nd other in SMPS
How can i add more fans and where can i add??
Which is the best company for good quality cooling fans??
@Tech_your_future
I searched in the hardware section but didnt find any thread related to this after searching.
May b my method of searching is wrong.
Plz mention some methods for searching too.
__________
Neeeeeeeeeeeed Heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeelp
Reason: Automerged Doublepost
20-01-2007, 10:41 PM
Re: How to keep the systm Cool
is two fan not enough???
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
21-01-2007, 12:15 AM
Resident Fanatic
i m in punjab, nd summers here r very hot.
also i only use one ceiling fan.
nd when i start my pc nd check the temperature of my pc it shows around 60 degree celcius.
i think its too much.
21-01-2007, 07:56 AM
I have recently bought an SMPS from a company named CoolerMaster and the cost of SMPS is 5500.00. There is also a special processor fan from CoolerMaster that cost 2500.00. This is a US company and is the best and most expensive company for cooling solutions. I am very happy with the product. But you wont get it in local market and I had to get it from nehru Place, New Delhi.
21-01-2007, 11:33 AM
Resident Fanatic
One can buy a good Graphics card in that amount.
I was talkking abt simple fans for blowing air out and in tp b placed in the cabinet.
21-01-2007, 12:02 PM
I am giving you the best cooling options in your worst heating conditions. For your information having 10 fans in a machine would fail if they are not good quality fans and are not properly placed.
21-01-2007, 03:50 PM
Resident Fanatic
I m thinking of placing one fan at the front for popping the hot air out frm Hard disk. Nd one at the side panel to pop out the hot air CPU. Wat do u think?
21-01-2007, 04:33 PM
This would have good effect only till you are running less processor hungry applications. If you have more processor hungry applications like games and 3d Max etc. then you require a processor and SMPS cooling solution also. I am telling you all this of my experience that I had about 4 months ago and especially with Dual processors which are very heat intenstive, you need these solutions. In other cases, having two fans that help cross ventilation in the machine body works very well.
27-01-2007, 11:22 AM
Resident Fanatic
Did some searching.
Read some old issues of Magazines nd got this
Source Chip Feb 2006
http://img183.imageshack.us/my.php?i...ed1copyfh4.jpg
27-01-2007, 12:44 PM
That is what I meant by good cross ventilation. BUT - you would not get such bodies easily even in Nehru Place. Of couse they exist but you will have to hunt in NP for this and also get the fans installed properly.
27-01-2007, 12:51 PM
Google Bot
do it my way... my cabinet is always open...
full ventilation..
27-01-2007, 12:54 PM
full ventilation..
That I think is one of the best ways if you do not want to spend on Cooler Master
27-01-2007, 01:12 PM
Resident Fanatic
Cant we create holes in the present one?
__________
Cant we make holes in the present one?
27-01-2007, 01:37 PM
LOL..That wont help..because the hot air would still remain inside despite n no. of holes you do.
27-01-2007, 01:54 PM
Google Bot
u can make 2 big holes... n fix a 2 120 mm fans ... 1 that throws air outside and 1 that sucks it inside...
27-01-2007, 02:05 PM
Resident Fanatic
I think i sud fix one at the front to blow air out frm HDD.
And another one at the side to Blow out Processor heat.
27-01-2007, 02:07 PM
Google Bot
dont keep both fans outwards.... keep 1 inwards n 1 outwards...
27-01-2007, 11:15 PM
simplest solution can be to remove both the side panels of the cabinet.
so there is no problem of hot air getting trapped,the whole atmosphere is accessible to ur pc for cooling.
with this u can do with just two fans
on for the smps and the other of processor
I live in Delhi where it is very hot in summers and I do not have an AC
and even with heavy tasks the temp never exceeds 50`c.
27-01-2007, 11:22 PM
#19 (permalink)
GUNNING DOWN TEAMS
How to keep the systm Cool ????
>>>>>>Dont start the system
on serious note..keep cabinet open..i do the same
28-01-2007, 08:18 AM
#20 (permalink)
Keeping the cabinet has one disadvantage ie., build up of dust. But even keeping it closed, I have to open and clean it periodically.
V.Prem Kumar
28-01-2007, 08:57 AM
#21 (permalink)
Still Shining!
I keep my system open all the time. Full ventilation all the time..Less dust accumulation if cabinet kept vertical.
@Manshahia Regarding your problem, you can connect one extra fan to your motherboard and fix it in the back of the cabinet for blowing hot air out.
Or else there are front panel displays available which fit in the extra CD drive locations in the cabinet that displays the current temperature, HD activity etc. You can connect three fans to this as it is directly powered from the SMPS, and similarly monitor their speed and set the active temperature.
Nokia N86 8MP
29-01-2007, 08:21 PM
#22 (permalink)
yes even i keep the cabinet open.. n u cn clean dust occassionaly if it is accumulated .. another advantage is u can quickly take out hard disks/cd/dvd writer & quickly put it back.. almost using it as an external drive (i.e if u want to)
29-01-2007, 08:24 PM
#23 (permalink)
Still Shining!
Yah, I am using it too as an external Hard Disk in the way you said. i have not even screwed it to Cabinet, rather kept it on top of a pile of books
Nokia N86 8MP
29-01-2007, 08:46 PM
#24 (permalink)
yay nice!
Search this Thread |
