Old 14-01-2005, 04:36 PM   #1 (permalink)
Default Choosing the right AGP card
Hi guys.
Please assign a rank to these parameters in order of imporance when buying an AGP card:
[The parameter to be considered 'foremost' while buying a graphics card has rank 1]:
(Values in brackets are examples)
1.Graphics Engine (Ex:GeForce FX™5700)
2.Video Memory (256M/128M DDR)
3.Engine Clock (425MHz)
4.Memory Clock 500MHz(250MHz DDR)
5.RAMDAC (400MHz )
6.Bus Standard AGP (8x/4X/2X )
7.Memory Interface (128-bit DDR )
8.Max Resolution (2048x1536 )
9.VGA Output (Standard 15-pin D-sub )
10.TV Output (S-VHS and Composite )
11.DVI Output (DVI-I )
12.Adaptor/Cable bundled
Thanks for the help.
impetus is offline
Old 14-01-2005, 07:20 PM   #2 (permalink)
1. 6.Bus Standard AGP (8x/4X/2X /PCI-e) ( you cant go on without deciding the interface first )
2. graphics engine
3. The following are usually a part of of the graphics engine
RAMDAC (400MHz )
4. video mem
5. Memory Interface (128-bit DDR )
6. the following 3 under one section. OUTPUTS ( depending on whether ull be using a diff kind of output or a tv out in the first place )
DVI Output (DVI-I )
7.Max Resolution (2048x1536 ) ( majorly depends on ur monitor )
8.Adaptor/Cable bundled ( not as important as performance )
No Mercy, No Limits.
theraven is offline
