Old 14-01-2005, 12:51 PM   #1 (permalink)
Default Troubling pop up with ie
i get a pop up
i am using spy bot sd still not able to remove this , mostly pops up when
page cannot be displayed with ie
http://540.scmg.net/randomsites/banner.aspx
Can it be removed manually ... a cookie can be found containing this
link and javascript to replace the default page with the above link
wht to do
vijaythefool is offline
Old 14-01-2005, 12:57 PM   #2 (permalink)
Default Re: Troubling pop up with ie
Originally Posted by vijaythefool
i get a pop up
wht to do
i think that prob can be also solved ...
but what about giving try to firefox..
it has good pop up blocker...even download manager ...
hope solves problem...
i think ie must come with good features too ...
if u r happy to stick with ie i think other external pop up blocker soft can help you.
....from what i can get.
be who u r :
Saharika is offline
Old 14-01-2005, 01:38 PM   #3 (permalink)
swatkat's Avatar
Use Google Toolbar to block pop ups.
Spy Bot SnD doesnt bloack Pop ups,it only blocks bad downloads with it's SD Helper BHO for IE.
http://swatrant.blogspot.com/
swatkat is offline
Old 14-01-2005, 06:09 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis logfile for a better assesment of your problem ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
