Old 18-01-2007, 08:36 PM   #1 (permalink)
Living to Succeed
ajayashish's Avatar
Default 2mbps is in the wire or username
well i have a home 500 plan and i use my office internet username for 900UL. I am sudden;y getting download speed of 200kbps in torrents... so does that mean that the speed is in the WIRE that is connected... i think MERE MATHE ME AB KHICHDI PAK RAHAI HAI...
what do u says guys if this happneds i will take a 900UL and a home 250... and u know what will happen next
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 18-01-2007, 08:38 PM   #2 (permalink)
rahul_becks23's Avatar
Default Re: 2mbps is in the wire or username
plz. explain in plain english
rahul_becks23 is offline
Old 18-01-2007, 08:43 PM   #3 (permalink)
eagle_y2j's Avatar
speed to user name mai hoti hai server decides clients speed
Registered LINUX USER #438929
eagle_y2j is offline
Old 18-01-2007, 08:53 PM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Neither.
u can get any speed via the wire, provided u apply for it.
It's not in the username, as u don't have to change it to get a higher/lower speed connection.
But yes, the speed is decided @ the server-end, depending what connection u applied for.
By ur question, u might have got speeds of 200kbps in ur Home500 plan, even though u should get speeds of upto 2Mbps, right. Ur UL900 plan'll give u speeds of ~256kbps but the Home500 plan'll give speeds upto 2Mbps, which means u can get the 200kbps speeds here too. U might not get a constant speed of 2Mbps, until & unless, maybe, u r residing near the main server of ur BSNL exchange, and there r very few BSNL customers other than u in ur area, for u 2 share the bandwidth. The more people to share, the slower ur connection'll turn out
koolbluez is offline
Old 18-01-2007, 08:56 PM   #5 (permalink)
the bsnl exchange is 3-4 kms away from my house...........what do u think.....will i get proper 2mbps and also.....not many bsnl users are here.
So,should i downgrade my 900UL to 500 plan.
Old 18-01-2007, 09:16 PM   #6 (permalink)
Living to Succeed
ajayashish's Avatar
are u are not getting me properly...
i applied for home 500 and i am using this. Now friend who has 900ul plan has given his username and password to me and i am using that to save the bandwidth...
now i am still getting a download speed of 200kbps... do that means no matter what username u use u will get that speed as i have applied to that plan..
Old 18-01-2007, 09:21 PM   #7 (permalink)
24online's Avatar
kbps or KBps ??
is it work on phone no. as IP ??
means any username u use...or ur telephone no. binded with speed limit...
**#(o)#**
24online is offline
Old 18-01-2007, 09:22 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
where do you put the User Name in BSNL BB.
i've never used it to connect.
i use it to check the Monthly Usage @ dataone portal. where else can we use this user name/pass
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 18-01-2007, 09:22 PM   #9 (permalink)
ok , i got that....... nice info .
Old 18-01-2007, 09:31 PM   #10 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
So u r using ur friend's 900UL plan & u get 200kbps, what's the prob?
U r supposed to get sub-256kbps speeds on the 900UL plan.
It's not based on phone also, afaik. In ur sense, the plan taken by the username is utilized... meanin UL900 which runs ~256kbps.
Wait a minute, did u mean 200kBps or 200kbps?
200kBps ~ 200*8=1600kbps ~ 1.6Mbps...
So u got 1.6Mbps or 200kbps?
Old 18-01-2007, 09:34 PM   #11 (permalink)
Living to Succeed
ajayashish's Avatar
see when i use my plan home500 it gives a speed o 256kbps and in the same line when i put the username and pass of my friends 900ul it gives same speed...
that means i am getting a speed of 2mbps unlimited ...
Old 18-01-2007, 09:38 PM   #12 (permalink)
that is really cool trick .............
Old 18-01-2007, 09:42 PM   #13 (permalink)
a_g = JPKN
s18000rpm's Avatar
hey ajay dude, can you pls tell me how to put user/pass of other plans for 900ul.
coz my frnd too has 500plan & i want to d/l some stuffs a bit fast.
i'm using Huawei modem (SmartAX MT880), its autodial thing.
Old 18-01-2007, 09:44 PM   #14 (permalink)
Living to Succeed
ajayashish's Avatar
then does that mean that the speed comes with the type of connection we apply for and not the username we get... i will shift to 250 plan then and use my friends username when i need to download...
__________
y is it is autodial... reset the modem and use normal PPPoE dialer ...
Old 18-01-2007, 09:47 PM   #15 (permalink)
a_g = JPKN
s18000rpm's Avatar
sorry, i dont know this pppoe thing.
but its in that mode only.
Old 18-01-2007, 09:53 PM   #16 (permalink)
Living to Succeed
ajayashish's Avatar
make ur modem in bridge mode and use a dialer
Old 18-01-2007, 09:56 PM   #17 (permalink)
mine settings are the same , i have to use a dialer and am on bridge mode
Old 18-01-2007, 10:03 PM   #18 (permalink)
Living to Succeed
ajayashish's Avatar
yes he is having a PPPoE and the username and password is saved in the mdoem so when he switches on the modem he is connected...
