Old 18-01-2007, 06:28 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default RDBMS help needed
Well i am doing my 4th sem of Engg. We have this RDBMS paper where we use oracle as the database n SQl as the interface.........
My doubt is if i create a table at the PC at my home how do i use the same table at my friend's place or at the college computer???????
The summary is how to get the copy of my table onto some removable media?
I have already tried posting in the Software section but got no replies......
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-01-2007, 10:48 PM   #2 (permalink)
shantanu's Avatar
Default Re: RDBMS help needed
ok ,, So you can try this,
Try msaccess.. when you save the file save it on desktop or any folder you want then open msaccess.. and open your file there inDBMS mode..
after that save your file as a access database file and copy it to your college or friends comp. then run it in oracle.. it will work... otherwise check PROGRAM FILES AND ORACLE DIR FOR YOUR FILE
shantanu is offline
Old 18-01-2007, 11:04 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Oracle has functions for exporting tables.
Check it out here
Nokia N86 8MP
Lucky_star is offline
Old 19-01-2007, 12:21 AM   #4 (permalink)
Check it out here
Thanks man repped u for the help.......My problem is sorted out.
Sony Vaio CW26FG
Old 19-01-2007, 12:23 AM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Thanx Buddy...
I don't remember the exact commands now, but I had done quite a lot of stuff like this in my 4th semester. Its my 6th semester now...
Nokia N86 8MP
