Old 18-01-2007, 05:51 PM   #1 (permalink)
You'r Born Free
int86's Avatar
Default RAM buying
I have a mercury mobo @266 (845GLM) with 128 ram ddr (brand mercury).
want to but a 512 stick.
Local dealer say ram less than @400 are not avaliable locally.
Will 512ram @400 will be compatible with my old 128 ram @333 ram.
Suggest price for 512 ddr @400 with price and Ram.
I am going to buy a ram soon.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 18-01-2007, 06:30 PM   #2 (permalink)
rahul_becks23's Avatar
Default Re: RAM buying
Buy Kingston 512 MB 400 MHz , there'll be no compatabilities problems.
Price varies place-to-place.
U should get it ar. 2.8K(probably less)
rahul_becks23 is offline
Old 18-01-2007, 06:54 PM   #3 (permalink)
You'r Born Free
int86's Avatar
Kingston are not available nowdays at my place.
int86 is offline
Old 18-01-2007, 06:57 PM   #4 (permalink)
get Transcend
Old 19-01-2007, 11:40 AM   #5 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
u can check for a fake ram by looking up the IC no from the chip array on the ram module on the website of the chip producer like www.hynex.com
the only way to be sure to buy non-fake ram is to buy from a trusted reseller.
Rollercoaster is offline
Old 19-01-2007, 06:01 PM   #6 (permalink)
Tux Fan
shaunak's Avatar
Yes it will be compatible but both sticks will run @ 333mhz.
The better option would be to dispose your old 128mb stick and have only 512 mb running at 400MHZ for the performance boost.
Note: if your work involves a lot of video editing or cad work then keep both sticks. [you need more memory not faster speeds]
Price @street: 2400
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 19-01-2007, 06:32 PM   #7 (permalink)
You'r Born Free
int86's Avatar
My mobo works @233 only.
I m upgrading 4 installing ubuntu and 4 casual programs
int86 is offline
Old 20-01-2007, 12:18 PM   #8 (permalink)
well , there'll still be no compatability problems if u get a higher speed .
Old 22-01-2007, 11:04 AM   #9 (permalink)
you can always get the model name/no. of the ram module and look up on the net to see if that is backward compatible. also if yes then it will be easier to updrade in the future. u wont have to change the ram when u upgrade ur mobo.
Old 22-01-2007, 06:11 PM   #10 (permalink)
You'r Born Free
int86's Avatar
Placed an order for Transcend DDR 400 for Rs 2650 . I think its much. I will get it in 3 days.
int86 is offline
