Old 18-01-2007, 04:47 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default benefits of activating
could some1 list me the benefits of registering a product like xp or vista
is it true tht some features may b blocked if im not using an activated copy or everything is fine just tht 1 cant update the product
http://beingmanan.com
iMav is offline
Old 18-01-2007, 05:23 PM   #2 (permalink)
Exclamation Re: benefits of activating
It is true that if you will not activate then not only some but all features will be blocked. On my laptop I was having Windows XP Home with sp2 which I didn't activated after 30 days the windows does not start it was demanding me to activate windows. If I press cancel then it does n't start. I must tell you that activate is not like registering. Activating is necessary registering is optional.
abhijangda is offline
Old 18-01-2007, 05:35 PM   #3 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: benefits of activating
Activation is for starting the software and registering is to tell them that u are using it
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 18-01-2007, 06:18 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
I think activation is necessary in Vista.Without activation U cant run vista more than 14 days.
ravi_9793 is offline
Old 18-01-2007, 06:27 PM   #5 (permalink)
rahul_becks23's Avatar
u can update always.........
but u cant run unactivated vista for more than the specified time interval(maybe 30 days)
rahul_becks23 is offline
Old 18-01-2007, 06:50 PM   #6 (permalink)
iMav's Avatar
is it true tht an un-activated product for instance vista givs 1 a 30 day trial period .... and my question is tht within these 30 days wht 1 gets to use is a limited version or the fulll version of the software
iMav is offline
Old 18-01-2007, 06:59 PM   #7 (permalink)
its the full version
Old 18-01-2007, 07:01 PM   #8 (permalink)
iMav's Avatar
which means tht if i use the trial version (3o day period) i get the full version of the software and i dont need to activate the trial version
iMav is offline
Old 18-01-2007, 07:03 PM   #9 (permalink)
wtf r u sayin
Old 18-01-2007, 07:08 PM   #10 (permalink)
iMav's Avatar
its simple english ....
iMav is offline
Old 18-01-2007, 07:13 PM   #11 (permalink)
Google Bot
Pathik's Avatar
yup u get to use the full software witout ne disabled features 4 30 days..
Pathik is offline
Old 18-01-2007, 07:22 PM   #12 (permalink)
oh yeah
Old 18-01-2007, 07:25 PM   #13 (permalink)
iMav's Avatar
thank u for clearing tht .... just wanted to b sure b4 investing time and 20gb of hdd space
iMav is offline
Old 18-01-2007, 07:27 PM   #14 (permalink)
20 gb .... does it take 20 gb ful.....
