18-01-2007, 03:46 PM
folder with no name???
hey guys..is thr any way to create a folder having no name in win xp?????
18-01-2007, 05:01 PM
MVP Awardee 07
Re: folder with no name???
First tel me why do u need a folder without a name???
Names are there to identify a folder contents,..
I presume u wanna hide stuff.. you can do a small registry hack to avoid showing folders u wish not to be visible to everyone..
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
18-01-2007, 05:10 PM
Wise Old Crow
Create a new folder. Try the ALT+255 combination during renaming folders.
18-01-2007, 05:18 PM
Šupər♂ - 超人
U can make it i suppose... something to do with changing the name to <space> via <cmd>. Used to do it long time back. Bhool gaya. Searchin online. 'll tell if i get it. Mayb other's know.
But there used 2 b a method. No doubt.
__________
ya... blueshift did it. I was tryin to do the same with Alt+32, the other <space> character code.
But i suppose, there is some problem with the method. I used to do it to prevent access to the folder. Can't remember the method though.
Reason: Automerged Doublepost
18-01-2007, 05:23 PM
Wise Old Crow
What you want to do koolbluez? That method will only rename the folders name to nothing.
ok folder created. Now how to delete ? Standard methods not working. right click delete, shift delte, nothing appears to work.
Gravitation can not be held responsible for people falling in love- Einstein.
18-01-2007, 05:26 PM
Wise Old Crow
What? Which OS u use?
It works perfectly here.
18-01-2007, 05:28 PM
Vista RTM ..
18-01-2007, 05:31 PM
Wise Old Crow
ok. I use WinXP.
Sorry can't help you.
18-01-2007, 05:33 PM
How do you delet it in XP ?
18-01-2007, 05:54 PM
delete the folder in cmd .
18-01-2007, 05:55 PM
Alright I got it how to delete in Vista.
18-01-2007, 06:15 PM
Šupər♂ - 超人
I was goin to say that some prob happens... u see, i did it sometime back.
Ok... but when i tried it on my Win XP SP2 it worked fine & I got it deleted. How come I didn't face ur prob. Maybe it's the SP2... jainshubhanyu?
Anyway, How didja do it?
DOS... rename the file & delete the renamed one. I suppose that'll work.
18-01-2007, 06:18 PM
maybe he deleted in dos...cuz its possible that way
18-01-2007, 06:21 PM
Wise Old Crow
what command we need to delete a folder having no name??
18-01-2007, 06:22 PM
well , i have no knowledge of that baby
18-01-2007, 06:58 PM
thanx blueshift...u rock man.. i wz trying with alt+180..but that wasnt working...
do nybody also know the registry hack for the same?????
19-01-2007, 04:34 PM
good blueshift
20-01-2007, 03:57 PM
#19 (permalink)
Host4Cheap.org
LOL, looks like he wanna hide that *private content* all guys have on HDD
1. Make a New Folder
2. Rename it and while renaming press ALT and then 255. It will leave a blank character.
3. Select the folder and change its icon to "blank" icon
4. Enjoy!! No need of *magic folders* tool
http://www.host4cheap.org/
Search this Thread |
