Old 17-01-2007, 08:43 PM   #1 (permalink)
jatt's Avatar
Question how to watch tv on monitor
hi friends can anyone tell me about my question can i able to watch my dishtv on monitor only i have only monitor not cpu,plz tell can i able to watch through zenega set top box or i have to purchase another software if i can do that please. thanks in advance
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 17-01-2007, 09:18 PM   #2 (permalink)
Default Re: how to watch tv on monitor
dear frnd. u can buy a cheap set top tv tuner card which dont require cpu to use ur monitor as tv. i think u can get a cheap intex tv tuner box for around a 1000 bucks.
varunprabhakar is offline
Old 18-01-2007, 06:48 PM   #3 (permalink)
saurav_nolakha's Avatar
you can buy an external TV tuner card and can then use monitor as TV without using CPU
The difference between impossible and possible lies in determination.
100ARAB 9LAKHa((saurabh nolakha))
saurav_nolakha is offline
Old 19-01-2007, 04:36 PM   #4 (permalink)
simply get a tv tunner card then proses forward
suraj is offline
Old 19-01-2007, 08:28 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
You Dont Need A TUNER CARD With SATELITE/TATA SKY/DISH TV
The set top box gives an out put in standard composite pin format.
The connectors look something like:
Exactly like standard VCR/DVD/VCD player connectors.
Connect this to the line in of your Gfx card with a converter.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 19-01-2007, 11:14 PM   #6 (permalink)
jatt's Avatar
shaunak i coulnot able to understand your post i have already told that i dont want to use cpu i want to use only monitor is there any way to watch tv chanles on monitor by any way without cpu i have dish tv
i hope you will give me good answer
anyway other frierds also thanks verry very thanks to you alll
jatt is offline
Old 20-01-2007, 02:40 PM   #7 (permalink)
Tux Fan
shaunak's Avatar
Sorry i misread your post.
You can do it,
You just need a composite to vga converter, it looks like:
http://www.virtualinformation.com/eb...es/vga-1lg.jpg
Then all you have to do it is connect the vga side into your computer monitor and the output pin from your box into the in port of the cable.
Forgive the bad imaging
Cheers
Shaunak
shaunak is offline
Old 21-01-2007, 11:27 PM   #8 (permalink)
jatt's Avatar
thankx shaunak now its right i will try it
jatt is offline
