Old 17-01-2007, 06:41 PM   #1 (permalink)
Default Sata 2 compatibility
Hi to all.
my pc includes 3.06ghz HT (533/1mb) processor, biostar's 865GV Micro 775 motherboard, samsung combo drive, transcend's jetram 512 ddr400 ram & 40 gb hdd.
wat i want 2 know, is my system compatible with 160 gb sata 2 harddisk?
thnx in advance.
Ashfaq
lonelychild is offline
Old 17-01-2007, 07:09 PM   #2 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Default Re: Sata 2 compatibility
well...what is sata 2???
panacea_amc is offline
Old 17-01-2007, 07:17 PM   #3 (permalink)
Pragadheesh's Avatar
Post Re: Sata 2 compatibility
i think dat ur sys shud ave 2 SATA ports.. so u can connect 2 160 GB hd..
also check ur Mother board if there is provisions for SATA hd..
Pragadheesh is offline
Old 17-01-2007, 07:34 PM   #4 (permalink)
Arsenal_Gunners's Avatar
hmm... I don't think it supports sata2 http://www.biostar.com.tw/products/m...%20Micro%20775
see it is mentioned nowhere.
and panacea_amc.Here are some details about sata 2
http://en.wikipedia.org/wiki/SATA_2#SATA_3.0_Gbit.2Fs
here is an extract which is most important-
The 3.0 Gbit/s specification has been very widely referred to as “Serial ATA II” (“SATA II”), contrary to the wishes of the Serial ATA standards organization that authored it. The official website notes that SATA II was in fact that organization's name at the time, the SATA 3.0 Gbit/s specification being only one of many that the former SATA II defined, and suggests that “SATA 3.0 Gbit/s” be used instead. (The Serial ATA standards organization has since changed names, and is now “The Serial ATA International Organization”, abbreviated SATA-IO.)
we commonly refer 1.5 Gbps as sata 1.
hope this clears things up
Arsenal_Gunners is online now
Old 19-01-2007, 01:14 AM   #5 (permalink)
Smile Re: Sata 2 compatibility
thnx 4 d replies
