Old 13-01-2005, 07:54 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default How to measure 1GB d/l limit??
ok...seems ...BSNL's Data 1 is launching.....on 15th.....and am going 4 it.....
so now my q is is there any soft to Measure....what i have d/l ..i mean...to check if am in 1GB slot or not.....yah i know..i can use any d/l manager ...and d/l then keep counting...how much i hav d/led ....but many times...u have to use the default..d/l method ...due to antileech....so ...is there any soft..which wll keep track ...of what i have d/l ..i mean a All in 1 Utility ???
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 13-01-2005, 08:08 PM   #2 (permalink)
Hey,
I think you can use the 'Bandwidth Monitor Pro' program from http://www.bandwidthmonitorpro.com/ to address this issue.
Give it a try till you find a more suitable one.
Ciao.
Logix is offline
Old 13-01-2005, 10:26 PM   #3 (permalink)
I used DU meter which was very good. You can find out data transfer taken during a week, month or year.
Discussed here too!
Whatever happens, happens for good!
ramank is offline
Old 13-01-2005, 11:36 PM   #4 (permalink)
try netlimiter.
Its the best.
mR_iNDIA is offline
