16-01-2007, 05:00 PM
F Drive is missing
hey everybody i am new to this forum and i am fan of digit magazine, i have problem so i want you guyz to help me ,
my friend and i both use my computer and one day i save some my files in to my drive f: then i used one software to hide drive f: so that my friend can,t view my files and i used to view drive f: through run command but before one week that sofware got some problem and it is not working and i don,t know where to find anther one and my freind letf so now i am the only one who use my computer so i want my drive f: back and i don,t know how to get it back i tried gpedit.msc but i can,t get it back the only way i can access f: drive is through run command so if anybody knows anther way i can get my drive f :back please tell me...........
16-01-2007, 06:57 PM
Re: F Drive is missing
My friend has a similar prob.
He locked a 10 GB folder wid a software & forgot the password.
Now it is occupying the 10 GB & shows only 0 KB in folder properties.
Can't be accessed even from new window installations.
_______________________________________
Inflation is so high that it was written in a restraunt that--\"Prices are subjected to change between meals\".
16-01-2007, 07:35 PM
Still Shining!
Reinstall that software which you used before- exactly in the same place where you had installed it before. Now provide the old password and see if this works.
@Spyder- Full Format that drive in order to get rid of the locked space.
Nokia N86 8MP
16-01-2007, 09:44 PM
yeah BOTH THE ABOVE SUGGESTIONS ARE THE BEST WAYS..
try REPARTITIONING YOUR HDD BY DM... IT WILL SURELY WORK AND THEN REINSTALL WINDOWS
16-01-2007, 09:58 PM
Super Hero - Super Powers
Smart solution......
Minds are like Parachutes :arrow: They work best when open
16-01-2007, 10:57 PM
yeah FULL FORMAT OR REPARTITION
16-01-2007, 11:24 PM
Rebooting
try a thing or 2 before formatting...
Just Right Click of My Computer on the start menu, the select Manage
now go to Disk Management to see whether any Partition is hiding without a drive letter of any such... post a screen shot here of the Disk Management if nessacery...
rebooting
ChotoCheeta.com
17-01-2007, 12:31 AM
TooR
the usual way is to reinstall that software and use it to unlock ur drive...this is why I hate file and folder locking softwares...
I wish !!
17-01-2007, 01:02 AM
yeah !!! these softwares puts you in trouble and then wont help you!!!
17-01-2007, 11:50 AM
me i can access the files in my drive but the problem is when you click on mycomputer that drive will not show up. C: and D: and E: and G: for da cd-drive only will show up but when i want to access the f: drive i have to go run command then type f:\ then that is the only way i can access my files
17-01-2007, 11:51 AM
ask vishal for dis, he must knws some registery tricks to help you out ....
17-01-2007, 11:57 AM
Still Shining!
Goto Control Panel->Administrative Tools->Computer Management->Select Disk Management.
See if the F: drive is allocated properly. Try Changing its drive letter.
Nokia N86 8MP
17-01-2007, 02:32 PM
Microsoft MVP
Open "regedit" and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer
In right-side pane, look for following DWORD values:
NoDrives
NoViewOnDrive
If exist, then delete them.
17-01-2007, 09:50 PM
dekha,,kaha tha na..!!!
17-01-2007, 10:31 PM
Microsoft MVP
lol, thnx buddy but lets see whether he got his problem solved or not by using the trick!
17-01-2007, 10:40 PM
GUNNING DOWN TEAMS
if he replies back ..  ..
if he doesnt then the problem is solved and if does then he still has the problem...this what i have seen on forum..very few members comback and give feedback abt solution given to them if it is correct one
18-01-2007, 01:16 AM
Absolutely right...
19-01-2007, 02:23 PM
thank u guyz for trying to help me and by theway i get that software which i used to hide my drive and i installed it back and now i get my drive back
19-01-2007, 02:26 PM
#19 (permalink)
Microsoft MVP
Thats the right way!
Always post in thread, if ur problem has been solved so that other members can know the solution, if they also face the same problem in future.
19-01-2007, 04:04 PM
#20 (permalink)
vishal is right .
pl do the same
Search this Thread |
