Old 14-01-2007, 01:12 PM   #1 (permalink)
Case Mod - 60% ||||||----
spynic's Avatar
Default "Electronic" question
hey guys.. im workin on a case mod.. so needed some electronic help..
i needed help on creating a momentary switch for operating a 12V circuit.. probably using some logic gates or some IC's..
needs to be like a latch.. on pressin once=turns on, pressin again=turns off.. and so on..
i found some references,, doubtfull bout which to use
http://www.cpemma.co.uk/flipflop.html
http://www.electronics-lab.com/proje...024/index.html
http://www.doctronics.co.uk/4011.htm
spynic is offline
Old 14-01-2007, 01:42 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: "Electronic" question
Well my suggestion is to use FlipFlop.
Coz
1. I have tried it, it works nice.
2. As u r asking to work on 12V & it can work on 12V.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 14-01-2007, 02:35 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
enggs darling 555
http://beingmanan.com
iMav is offline
Old 17-01-2007, 10:00 PM   #4 (permalink)
spynic's Avatar
thanx mate.. 555 is a real blessing!!
spynic is offline
Old 28-06-2007, 03:44 PM   #5 (permalink)
spynic's Avatar
hey tried this circuit out..
but it remains in "on" state..
doesnt evn go off..
ne clue?
i get a 0V reading b/w R1
spynic is offline
Old 28-06-2007, 03:44 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
Check Transistor and 555
Charan is offline
Old 28-06-2007, 08:23 PM   #7 (permalink)
spynic's Avatar
workd!
555 loose connection.. (testing on a breadboard...)
thnx!
hey electronic schola's...
wt if i had to run a 2amp 12V(approx) ciruit on this..?? wt changes wud i hav to make?? i already put heat sinks on the TIP31C
n put higher wattage resistors.. ne other changes, so tht it works fine for a long time..(n nothin blows)
spynic is offline
Old 28-06-2007, 08:56 PM   #8 (permalink)
Use a 12v relay to run a heavy load.
sashijoseph is offline
Old 28-06-2007, 10:04 PM   #9 (permalink)
spynic's Avatar
ne specs for a relay?
spynic is offline
Old 29-06-2007, 08:08 AM   #10 (permalink)
Get a 12volt spdt relay with contact rating >= load to be driven(in your case 2amp or more).You may also try a pcb mount type(for compactness).
As for the ckt look here... http://ourworld.compuserve.com/homep...wden/page9.htm
