Old 13-01-2005, 02:35 AM   #1 (permalink)
Default N-gage newbie
I just bought a n-gage (not qd).
But i cant get it t oconnect to my pc (via usb).
All usb drivers are installed for my pc, installed the nokia software, did everything.....but the pc just doesnt detect the n-gage.
my os is win98se.
Also how do i know whthter my motherboard suypports bluetooth or not?
its msi-k71/72 something of that sort?
If yes, how do i enable bluetooth?
Plz help!
geekhead83 is offline
Old 13-01-2005, 02:58 AM   #2 (permalink)
SABER RIDER
maverickrohan's Avatar
Did u check ur USB ports first, try connecting some other devices to that port first......
n see if they work
About ur motherboard, its written in the manual, if it supports bluetooth or not, n I had assebled a PC with MSI KT4 ultra, which said it had bluetooth, but the catch was, u needed to get a dipole antenna to activate it, if u dont have one, i guess no bluetooth for u
Bluetooth dongles are avilable for 800-1000 bucks...try these....or if u can find the dipole antenna for a cheaper price...GOOD 4 U
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 13-01-2005, 11:23 AM   #3 (permalink)
Ethan_Hunt's Avatar
Ok To Begin Win 98 Sucks For The Detection of The Data Cables Usually......Try Using The Provided Cable On Windows Xp It Detects The Cell and The Cable Without a Flaw......cause In my Previous Case My Usb Infra-Red Cable Used to Detect My Phone on win 98 but after sometime it stop Responding to it and even if it did it frequently Got Disturbed during File Transfers But When i swtiched to Xp Voilla All's Goin well now for me 8) (pssst This was a Advice given to me by a friend who owns a N-gage And Transfers his files Via The data cable provided over XP 8))
Well as for The Bluetooth i dun suppose Ur Mobo Has one......Get Urself a Dongle It would be better
Ethan_Hunt is offline
Old 13-01-2005, 12:20 PM   #4 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
ok
my friend buys a NGAGE (not qd)
he comes over to my house with the usb cable teh cd's et all
we try half an hour to make my pc recognize the phone
but my pc (win xp) says no way boss i dont know whats that
end result friend fed up geso back home with a heavy heart
but i bang shoot FF and type in the problem
15min into serching i found this
windows will recognize the phone "ONLY" after
you add in a mmc card to your phone
so my friend shelled out some 900 rs for a 128mb mmc
we tried a 256mb one but the phone started hanging (maybe not supporting 256mb)
so got a 128mb mmc
back to my house
got the usb wire
connected it to the pc
and voila
windows showed the phone as a portable storage device
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 15-01-2005, 12:01 AM   #5 (permalink)
Well, my cell already has an MMC of 32 mb....the one that came with it.
As far as trying out other devices to connect, dont hae any usb devices...
Dunno what to do....will have to locate a freind who has an n-gage or usb...
Need some good tipis n tricks for the n-gage.
Any good links, i tried searching this forum, but didnt find any tips as such!
Old 26-01-2005, 03:34 AM   #6 (permalink)
well was fianlly able to connect the n-gage to a win2k pc via usb.
thanks 2 all!
Old 28-01-2005, 04:13 PM   #7 (permalink)
dattebayo
anispace's Avatar
try bahrainmobiles.com register for free and search the forum for free games for ur ngage.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
