Check this
hey ! if u got a calleer id capable internal modem please tell me the model and the make i need one
The re are many software like talking caller id, modem spy , ascendis caller id , accubell caller id... etc for modem to record caller information and many more functions....
To check if ur modem is caller id capable do this simple check____
To use Caller ID software products you need two things:
Caller ID Service From your local telephone company
A MODEM or hardware device that supports Caller ID
The first is required as only your local telephone company can supply this data. The second is required so that the data sent by the telephone company can be passed to software programs for processing.
Many current MODEMs offer support for Caller ID. The key question is always what setup string to use to enable Caller ID (virtually every MODEM disables Caller ID as the default).
For most MODEMs, the string AT#CID=1 or AT+VCID=1will enable Caller ID. Look in the user’s manual for your MODEM to see if any setup string is referenced or mentioned.
Other common setup strings are:
AT#CID=2
AT%CCID=1
AT%CCID=2
AT#CC1
AT*ID1
The best way to test is to use a terminal data program. In Windows 3.X, the TERMINAL program (usually in the accessories folder) can be used, (be sure you set the COM port to the PORT your MODEM uses). In Windows 95/98/ME/2000/XP, the HyperTerminal program can be used.
To use HyperTerminal do the following:
1) Select "HyperTerminal" by navigating through the Start button to "Programs," then "Accessories," then "HyperTerminal"
2) Double click on "hyperterm" or "hyperterm.exe"
3) Name the new connection "test," and select OK
4) Change the "connect using" to Direct to COM X, were X is the COM port used by the Caller ID device
5) Click on OK on the screen for port settings
To test your MODEM, do the following:
1. Type the string ATZ, (OK should appear on the screen)
2. Enter the Caller ID string to be tested, (AT#CID=1 or AT+VCID=1 for most modems)
3. If OK results, continue; If ERROR results the modem may not support Caller ID; try a different setup string
4. Have someone call you and watch the terminal screen
5. If Caller ID is working, you will see the word RING, followed by one or more additional data lines. The word RING will then continue to appear for each incoming ring.
6. If Caller ID is not working, you will only see the word RING for each incoming ring. If this is the case try another setup string and go back to step 2.
The most common result, when Caller ID data works, is the following:
RING
DATE = xxxxx
TIME = xxxx
NMBR = xxxxxxxxx
NAME = xxxxxxxx
RING
RING …
There are other formats as well. The key point is that other data generally appears between the first and second rings.
