Old 10-01-2007, 08:29 PM   #1 (permalink)
Cool help me in powerpoint. want to insert mu
I want to insert music in powerpoint slides how to do that? it is not that much simple . what I exactly want to do is this >
say I have 7 slides 1 to 7 . Now from 1 to 3 I want it like this >>
that when I start a song starts( song a ) then when i am in slide 2 song B starts then when I am in slide 3 song C starts.then there will be only one song ( song D) for slide 4 to 7 . I mean I may roam any slide between 4-7 but the song will play uninterruptly .it should not start from the beginning if I go to a different slide .
is that possible??
pkt3000 is offline
Old 10-01-2007, 09:43 PM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: help me in powerpoint. want to insert mu
i dont think so.. u can post feature request to Microsoft.. LoL
amitava82 is offline
Old 10-01-2007, 10:21 PM   #3 (permalink)
Wise Old Crow
blueshift's Avatar
Yes its possible.
For slides 1,2 and 3, insert audio to each slides using Insert>Movies and Sounds>Sound from file menu. So when these slides appears it will play its own music you put in those files.
For slides 4 to 7, follow the same procedure of inserting audio as above in slide 4. Goto Slideshow>Custom Animation to show the Custom Animation panel on right. See the uploaded file
Select your sound icon(triangle like). Then goto its dropdown menu and select Effect Options. In the new window that will come up, under Effect tab, click on the radio option that says 'Stop playing after .. slides'. Enter value 7 there.
It will definately work!
http://twitter.com/blueshift155
blueshift is offline
Old 10-01-2007, 11:01 PM   #4 (permalink)
MMO Addict
amitava82's Avatar
there is a small problem with the blueshift's method. everything works fine when you go forward. But when when go backwards from slide 7, 6, 5 to 4 the song stops playing and you have to go back to slide 3 and come back to 4 and the song starts playing again..
Old 10-01-2007, 11:19 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
so thts how it is wats wrong thts the logic
http://beingmanan.com
iMav is offline
Old 11-01-2007, 10:22 AM   #6 (permalink)
thanks to Mr blueshift and and mAV3 . and Mr amitava82 please dont confuse others . It is not that what u dont know is cannot be done. dont say like this "i dont think so.. u can post feature request to Microsoft.. LoL" . No I is important here . if u dont know just dont answer .
reddragon is offline
Old 11-01-2007, 10:59 AM   #7 (permalink)
MMO Addict
amitava82's Avatar
Linsten Mr. Dragon or whatever, the way he wanted the job to be done is not possible completely n the problem too i posted. SO my REQUEST to you is "DONT COMMENT BEFORE YOU READ" got it?
Old 11-01-2007, 06:28 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Take a chill pill guys.
@amitava82: I did my best to solve this problem. Btw, happy birthday to you.
Old 11-01-2007, 08:18 PM   #9 (permalink)
MMO Addict
amitava82's Avatar
thanks man. by d way, i just pointed out whats d problem with that method. your solution is 99% correct except that small problem. and there is nothing wrong to put a feature request to MS
Old 11-01-2007, 08:40 PM   #10 (permalink)
Security Exp
47shailesh's Avatar
Hey Guys why dont you use macromedia to make presentations, even the 1% prob that amitava82 is talking will not be in this case...
We Love Once, And When We do We do it Well
47shailesh is offline
