Old 10-01-2007, 12:25 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Torrent STOPS ! ! !
i have installed utorrent ...... have q-ed many ebooks 4 downloading ..... some have complete 100% .......
bt if i double-click 2 check, it gives me any error .... same is regarding mp3 &
video files 2 .......
is something wrong with software, should i change it or any settings i have
left out ?
ax3 is offline
Old 10-01-2007, 06:24 PM   #2 (permalink)
Default Re: Torrent STOPS ! ! !
what error does it give?
legolas is offline
Old 11-01-2007, 11:21 AM   #3 (permalink)
ax3
ax3's Avatar
cannot open file ....
ax3 is offline
Old 11-01-2007, 12:28 PM   #4 (permalink)
morpheusv6's Avatar
Maybe the torrent file is bad or the download is corrupted. Check for previous user rating before you download.
Deven
morpheusv6 is offline
Old 11-01-2007, 04:51 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
did you have power-cut during downloading of those files.
when NFS Cabon Demo came out, i was downloading that file, & when the download was @ 95%- power cut.
i selected "resume Download" from Opera, & it did get completed 100%.
but when i tried to open, "Error, cannot open file, the zip file may be damaged"
7 hours of waiting anxiously, gone waste.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 12-01-2007, 02:27 AM   #6 (permalink)
El mooooo
eddie's Avatar
^^ Time for someone to start using real torrent clients
As to the OP: Stop your download and right click on it. Choose "Force recheck". utorrent will check the file and if it find some errors then it will re-download the particular pieces (not the whole file). If utorrent does not find any error and yet your can't open the file then you have a fake at your hand.
eddie is offline
Old 12-01-2007, 09:26 AM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
^^i was just downloading the file from EA's server, was not using Opera's torrent.
Old 12-01-2007, 11:47 PM   #8 (permalink)
El mooooo
eddie's Avatar
Then it is time for someone to start using real download managers
eddie is offline
Old 12-01-2007, 11:57 PM   #9 (permalink)
Waiting for 3 Miracles...
saurav29's Avatar
in the torrent preferences check mark that appent ut! to unfinished downloads in this way you will find out that even when 1 piece of the file is missing... it dies sometimes show 100 % if only a small piece is missing..............
i remember once i downloaded few files with extra security setting so right click on the completed files to see properties if any of the files are locked and needed to be unlocked before opening it will show you extra settings tab when viewing its properties and click on unlock to unblock before using them.....
peace
raj
saurav29 is offline
Old 13-01-2007, 12:19 AM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
i believe my problem was with data corruption, due to power cut.
but anyways i'm happy with Opera's download manager.
when i get atleast 512MB RAM, i'll go for other download managers.
Old 13-01-2007, 10:40 PM   #11 (permalink)
El mooooo
eddie's Avatar
I have heard Flashget takes below 10MB of RAM...
eddie is offline
