Old 09-01-2007, 08:25 PM   #1 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Default A Query to Solve.
Hey frens,
How can I access the files and folders present inside c: If a user have done the following
1. Restricted c:/
2. Remove Run Command
3. Remove Search
4. Rename GPEDIT.MSC
5. Hide GPEDIT.MSC
Waiting For Reply…………………..
||uLtiMaTE WinNER||
Ron is offline
Old 09-01-2007, 08:31 PM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: A Query to Solve.
If ur C: drive is FAT32, then u can create a MS DOS bootup flopppy disk, boot from it and access the C: drive files.
Nokia N86 8MP
Lucky_star is offline
Old 09-01-2007, 08:42 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U forgot about my favorite "regedit.exe"
U can disable the restriction from Registry Editor
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-01-2007, 08:46 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
@Vishal, he said he removed the run command and restricted C:
Now how can U access regedit.exe?
Nokia N86 8MP
Old 09-01-2007, 08:52 PM   #5 (permalink)
Microsoft MVP
Type "regedit.exe" in addressbar of explorer
Old 09-01-2007, 08:58 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
What does restricted here mean?
Does that mean that one cannot make any changes to the files?
If that's so, then how come changes to the registry be made, as the registry itself resides in the C:
Nokia N86 8MP
Old 09-01-2007, 09:23 PM   #7 (permalink)
Microsoft MVP
Restricting C: means, u can't open C: drive from explorer as well as from other methods, like RUN dialog box, etc.
I never tried it but I think "regedit.exe" should open from addressbar.
Old 09-01-2007, 09:33 PM   #8 (permalink)
Google Bot
Pathik's Avatar
he can run c/windows/regedit.exe
Pathik is offline
Old 16-01-2007, 06:53 PM   #9 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
hey frens is there no way to access the data...........
||uLtiMaTE WinNER||
Ron is offline
Old 16-01-2007, 11:23 PM   #10 (permalink)
shantanu's Avatar
I THINK It CAN BE DONE BY REGISTRY EDITING IF VISHAL HELPS
shantanu is offline
Old 17-01-2007, 01:52 AM   #11 (permalink)
Microsoft MVP
1.) Give following command in RUN dialog box:
REG delete HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /v NoViewOnDrive
2.) Log off and login again.
3.) Now u'll be able to view and open C: Drive
Old 17-01-2007, 02:12 AM   #12 (permalink)
shantanu's Avatar
what i said
shantanu is offline
Old 17-01-2007, 11:44 AM   #13 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
hey vishal,
RUN is resctricted.........
||uLtiMaTE WinNER||
Ron is offline
Old 17-01-2007, 02:25 PM   #14 (permalink)
Microsoft MVP
Then type the command in Notepad and save it with "vishal.bat" name (including the quotes) and then run the file.
Old 17-01-2007, 06:35 PM   #15 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Hey Frens,
Try this solution –
Copy Gpedit.msc from any computer and try to access/open it……..........….in the computer you want…………………..
Pls reply…………
I will be waiting for it………….
Hey vishal,I will try ............
||uLtiMaTE WinNER||
Ron is offline
Old 19-01-2007, 11:30 AM   #16 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Hey vishal........
Unable to open the restricted drive...........
Error message displayed..................
||uLtiMaTE WinNER||
Ron is offline
Old 19-01-2007, 01:08 PM   #17 (permalink)
Microsoft MVP
It works here perfectly.
Try to restart the comp.
Old 20-01-2007, 10:08 AM   #18 (permalink)
vishal is right.
restart ur computer and logon as a "administrator"
then fallow what vishal said
suraj is offline
Old 20-01-2007, 11:38 AM   #19 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Hey vishal,
thxs……It worked………....By mistake…… i was applying wrong command....... I had prevented the drives to access it from My Computer…………………….
Anyways...Thxs again.....
& hey Could u pls tell me the format to write the command………..what is the use of /v ?
||uLtiMaTE WinNER||
Ron is offline
Old 20-01-2007, 08:50 PM   #20 (permalink)
Microsoft MVP
/v stands for Value, i.e., The value which has to be altered using the REG command.
The syntax is:
REG Operation Key_name /v value_name
Old 21-01-2007, 11:31 AM   #21 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
thxs buddy......
||uLtiMaTE WinNER||
Ron is offline
