Old 07-01-2007, 11:18 PM   #1 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Exclamation Desktop Recorder !!!
Long time back I came across a s/w which records anything seen on the desktop.
Not something which records from the card, or from a url or so...
a "direct view recorder"... a "what u see is what u record" sorta software. Does anybody have any idea on that kinda software?
Something like a desktop capturing utility in the recording mode
koolbluez is offline
Old 07-01-2007, 11:52 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Desktop Recorder !!!
there are a lots of 'em, but i couldn't find a free one.
link->Desktop Recorder (its the search result of google, just d/l what u like)
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 07-01-2007, 11:55 PM   #3 (permalink)
MMO Addict
amitava82's Avatar
http://www.techsmith.com/camtasia.asp
amitava82 is offline
Old 08-01-2007, 09:03 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
My Screen Recorder's just great !!! Than q.
Old 08-01-2007, 09:52 AM   #5 (permalink)
mayneu's Avatar
Talking Re: Desktop Recorder !!!
just use this software buddy, u will forget every other software. compression rate is better than techsmith's camtasia. i agree that camtasia is the best. but its heavy in size both the programme & the recorded file size.
its called BB FLASHBACK. the link is here.
http://www.bbsoftware.co.uk/bbflashback.aspx
what more, it can record audio also if u have sound card. its simply the best software. fastest and small in size, best quality. use it to believe it.
mayneu is offline
Old 08-01-2007, 03:17 PM   #6 (permalink)
"Technologic"
Apollo's Avatar
Originally Posted by amitava82
This is a great tool for screen capture. I'd recommend the same.
mayneu: Checking out your link now...
One great use of words is to hide our thoughts.
Apollo is offline
