Old 05-01-2007, 11:58 AM   #1 (permalink)
What? Where? How?
escape7's Avatar
Default Creating a moving image - Need Help!
Here's the scenario : I have 5 images, how do i make it into one? Like one image appears, then the other comes, then the third and so on... Moving image sort off as in a GIF. I hope i'm clear enough...
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 05-01-2007, 12:06 PM   #2 (permalink)
JhonCena's Avatar
Default Re: Creating a moving image - Need Help!
Use Adobe Imageready comes with Adobe Photoshop
----------> http://www.blogofwebmasters.com/ <---------
WEBMASTERING TUTORIALS, ARTICLES AND MUCH MORE
JhonCena is offline
Old 05-01-2007, 12:18 PM   #3 (permalink)
What? Where? How?
escape7's Avatar
Thats one solution, but the problem is that i don't have photoshop... any softwares you guys know of?
escape7 is offline
Old 05-01-2007, 12:22 PM   #4 (permalink)
Kiran.dks's Avatar
You have two options,
GIF creator: Use a GIF creator, club images into it, specify frame rate and time to suit your need. The output file will be in GIF format
SlideShow creator: Use a slide show creator like Picasa, load images, specify time and transition effects and save as a exe file.
Kiran Kumar R
Kiran.dks is offline
Old 05-01-2007, 12:27 PM   #5 (permalink)
What? Where? How?
escape7's Avatar
I have to use it in a website, so "exe" would be a problem. Do u have any gif creator which is easy to use?
escape7 is offline
Old 05-01-2007, 03:00 PM   #6 (permalink)
tuxfan's Avatar
You can use Javascript to create a quick slide show of images which will look like an animation. For best results, pre-load the images.
tuxfan is offline
Old 05-01-2007, 03:49 PM   #7 (permalink)
The Devil's Advocate
iMav's Avatar
http://www.javascriptkit.com/script/...bleslide.shtml
go ^^ and se if it helps
http://beingmanan.com
iMav is offline
Old 05-01-2007, 05:17 PM   #8 (permalink)
What? Where? How?
escape7's Avatar
Yup, the javascript solved the problem, thanks guys
escape7 is offline
Old 05-01-2007, 05:19 PM   #9 (permalink)
Kiran.dks's Avatar
There are many GIF creators on net.
One of the best is Active GIF Creator 2.23
Kiran Kumar R
