04-01-2007, 10:17 PM
Why do pc monitors have picture adjustments?
Why do CRT pc monitors have all those adjustment buttons below the screen which lets you adjust the picture left, right, up, down, expand, contract, etc? Why can't they display picture normally like a regular CRT tv? And if they're so important, why don't CRT TVs (even high end ones) don't have this feature? Also why don't LCD pc monitors have this feature?
04-01-2007, 11:56 PM
dattebayo
Re: Why do pc monitors have picture adjustments?
thats probably becoz TVs have a fixed resolution while CRT PC monitors have to work with different resolutions(640x,800x,1024x etc). So the picture might get distorted if the rez is changed n the controls can be used to adjust the image.
LCDs anywayz work best only with their native resolution.
all tvs have contrast adj
Yoda: No. Try not. Do... or do not. There is no try.
04-01-2007, 11:59 PM
Microsoft MVP
Such options are available for TVs also in the Service Menus
I hv Sony & LG TV in my home and hv opened Service Menus of both of them
05-01-2007, 12:19 AM
Still Shining!
Is there any way or any secret code by which we can get in to to the Service menu in TV?
Nokia N86 8MP
05-01-2007, 12:33 AM
Microsoft MVP
Yes! All Digital TV contains some secret codes to enter into Service Menu
These codes are different for each brand and even for each model
I use following codes for my TV:
For Sony TV:
First power off ur TV using remote, then Press <Display> + 5 + Vol Up + Power button simultaneously on remote. To save the changes, just press Mute + 0.
For LG TV:
Press and Hold <OK> button on remote as well as TV panel at the same time for a few minutes. To save the changes press <OK> in Remote.
PS: Be very careful while playing with the service menu  if something goes wrong, just swicth off the TV and switch on it again
05-01-2007, 12:42 AM
Living to Succeed
any secret menu for Samsung///
05-01-2007, 12:43 AM
Still Shining!
Thanks for the replies, Vishal. I will try it on my old LG tv. Now, I have got a Samsung Model. Do you have any code for those?
Nokia N86 8MP
05-01-2007, 12:57 AM
Microsoft MVP
For Samsung, try this:
Power off TV using remote and then press MUTE + 1 + 8 + 2 + Power Button from remote simultaneously
I hv tried this code once for an old samsung model, can't remember the model name, so don't know whether it'll work for ur Samsung TV or not?
05-01-2007, 12:59 AM
Living to Succeed
i think it will be pwer off > Display>menu>mute> power on
05-01-2007, 01:05 AM
Still Shining!
As you hav mentioned about it, I will start experimenting with it from tomorrow onwards.
Is it for Samsung?
Nokia N86 8MP
05-01-2007, 01:13 AM
Microsoft MVP
U should, buddy I enabled Golden Eye feature in my LG TV
When we purchased the TV, it did hv "Golden Eye" button in remote but it wasnt working coz my LG model doesnt hv this feature. But I was able to enable it from Service Menu  Now I'm enjoying Golden Eye feature in a non-Golden Eye TV
05-01-2007, 01:16 AM
something for SONY wega series
05-01-2007, 01:20 AM
Still Shining!
Golden Eye is a hardware feature, I suppose. They have a light sensor in the front which adjusts the brightness, contrasts according to the room light settings. So, if u hadn't that feature when u bought ur TV, how come is it working now?
Nokia N86 8MP
05-01-2007, 01:24 AM
Microsoft MVP
In my LG TV model, it was not available and also was not mentioned in the features list
Guess what they hv disabled it from Service menu to decrease the price of the model. But when I saw an option for enabling it in Service Menu, I didnt wait for nething and just enabled it
@vimal
I hv Sony Wega TV and the code mentioned in my above post works well for it
05-01-2007, 01:27 AM
Still Shining!
@Vishal- Now that's what called Free Hardware Upgrade
Nokia N86 8MP
05-01-2007, 02:05 AM
The Devil's Advocate
ya man frm registry to tv kya baat hai
http://beingmanan.com
05-01-2007, 07:32 AM
@Vishal Gupta does ur tv has a light sensor on the front, unless it is there golden eye will not work. On my TV it is on the right bottom.
05-01-2007, 07:47 AM
Golden Eye uses a light sensor on the tv's front panel to check the ambient light in the room. Without this sensor the Golden Eye feature is useless. Manufacturers use a common menu in many of their tv sets. So a tv without Golden Eye could be sharing menu with a Tv with Golden Eye. Thats why @Vishal you found the option of Golden Eye only in your tv's service menu and not in the manual or on the remote controller. In tv's with Golden Eye, LG makes a point to put the Golden Eye button on the remote and highlight it as its one of the key features. So don't get too happy about having Golden Eye feature for free. I once saw a 14" Samsung tv with Sound balance feature even though it had only one 50 watt speaker! It even had bass/treble adjustment and surround sound! It seems it was sharing menu with a higher end 21" Samsung tv.
Anyway thanks @anispace for your answer.
05-01-2007, 02:55 PM
#19 (permalink)
dattebayo
@vimal
@vishal
even i own a Sony wega 29inch. I had opened the service menu a while back but couldnt find any useful tweaks. Could u suggest some?
05-01-2007, 03:59 PM
#20 (permalink)
which is the display button dude 'wega gate'?sorry bought the tv on 1st so not much information about button names
05-01-2007, 04:19 PM
#21 (permalink)
Super Hero - Super Powers
Also TVs which don't have any option for service menu, have picture adjustment preset pots on the circuit board.
Minds are like Parachutes :arrow: They work best when open
05-01-2007, 05:45 PM
#22 (permalink)
Microsoft MVP
Very true. I used to play with those presets in my good old Jolly Color TV
@anispace
The oprions name r a little bit weird but play with them and u'll be used to them in a few minutes  U can use 1 & 4 buttons to browse thru options and can use 3 & 6 to change their values
@vimal
The Display button has i & ? printed on it
05-01-2007, 07:39 PM
#23 (permalink)
thanks reached there.man all letters and numbers,i was expecting a menu.I backed off for a while.
05-01-2007, 08:21 PM
#24 (permalink)
This is really interesting.. Any idea for an aiwa..??  about 6 yrs old..?? Or any web link for more info on the same..??
05-01-2007, 08:27 PM
#25 (permalink)
Microsoft MVP
OK guys!
I searched for a good site containing some info about these Service Menus and I got this:
http://www.fixyourowntv.com/servicemenu.php
So just try these methods to ur TV
05-01-2007, 08:32 PM
#26 (permalink)
thank you vishal for the site.Great help.
05-01-2007, 09:14 PM
#27 (permalink)
 Is it just me or has my thread gone a wee bit off-topic?
05-01-2007, 10:49 PM
#28 (permalink)
maybe...but it is one of the best pieces of info I have ever got.It is like registry in TV.
06-01-2007, 05:32 PM
#29 (permalink)
The Thread Killer >:)
Yeah man!! Cool! Well, how do you come to know which buttons to press in order to get into that service menu?? I got an Aiwa.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
06-01-2007, 06:19 PM
#30 (permalink)
The Devil
Mine is Akai and 10 yrs old. *blushes more*
Search this Thread |
