Old 04-01-2007, 08:56 PM   #1 (permalink)
Kiran.dks's Avatar
Arrow FREE DOWNLOAD:SPYWARE TERMINATOR, a good freeware!
Spyware Terminator 1.7.0.918
Spyware and adware cleaner+many other tools
Download: Spyware Terminator 1.7.0.918
Size 2.5MB
Friends, this new Antispyware is making waves. It has amazing interface and many people are reviewing it as a great program. It has real-time scanner. Give a try. Just install it and put for a scan. You may find some spywares in your system.
Scanning
-Fast Scan - Checks all important parts of your system (Processes, Libraries, Services, BHO, Toolbars, WinSock2, Startups registry, Uninstallers, Start menu, Desktop, Favorites, Cookies,...)
-Full Scan - Thoroughly checks Memory, Registry, Drive scans, NTFS ADS (optional), and scans for viruses using the ClamAV.
-Customized Scan - Allows the user to specify which parts of the system are supposed to be checked.
-Scheduled Scan - The user can schedule when the scan will start automatically.
-System Report - When the scan is finished, the user can see a report, including detailed information about the state of system.
-Antivirus Integration - Spyware Terminator allows users to integrate an open-source antivirus program, ClamAV, in order to extend the ability to detect malicious programs both during the scan and within the Real-time Shield. Updates of the antivirus database are downloaded automatically with Spyware Terminator updates.
Cleaning:
-Effective Removal - Removes threats effectively using the Spyware Terminator driver.
-On Boot Remover - Removes blocked files when the operating system boots.
-Quarantine - Allows the user to move potentially harmful items to special storage, and restore the original state when the user finds out that the item is safe.
Real-time Protection
-Real-time Protection constantly guards your system and ensures that spyware programs can be intercepted and disabled before they are installed, helping to prevent potential security breaches before a spyware program can run.
In some versions it uses the antivirus application ClamAV to prevent virus infection.
-HIPS - Spyware Terminator HIPS protects user’s computer from running unknown applications that can infiltrate your system through security holes within the system or any used application. During the Full Scan, Spyware Terminator creates a database of executable files of local disks. When this database is created and the HIPS function is active, any attempt of an unknown application or library to install is analyzed by the Real-time Shield. If the Real-time Shield cannot determine that it is a safe application, it displays a warning.
-The system of "automatic decision" will be perfected in upcoming versions that will minimize the user’s need to decide whether the installation should be allowed or not and maximize the security. For example, monitoring activities of unknown applications will be extended, and the ability to restore the system to its original state will be preserved.
-Predefined Profiles - Allow you to quickly configure Real-time Protection depending on the type of user.
-Allows full control and modification of important system parts such as Startup items, Services, Hosts, BHO.
Powerful Functions
-Computer Restoration - The user can restore the computer state to an earlier time, or to the default system settings
-File Analysis - The File Analysis utility allows users to send an unknown file (possible spyware) to our Crawler Spyware Central for deep analysis. Our experts analyze received files and then add them to our software database. The next time the user downloads updates that include analyzed file data, they will be able to remove the suspect file.
-Locked File Removal - Spyware Terminator allows you to also remove files that cannot be removed using standard methods because they are locked by an application.
Source: Spyware Terminator
Kiran Kumar R
Kiran.dks is offline
Old 04-01-2007, 08:59 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: FREE DOWNLOAD:SPYWARE TERMINATOR, a good freeware!
Interface somewhat like Spyware doctor
thanks
Tech Geek is offline
Old 04-01-2007, 11:04 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
it was once a rogue anti-spy !
"the company behind the product, had established connections with IBIS, a well known adware distributor responsible for such adware programs as Wintools, Websearch, & Huntbar...
...but now as the program itself exhibits no problems serious enough to warrant mention on this page, we have decided to de-list Spyware Terminator from the Rogue/Suspect list and can no longer regard the program to be "rogue/suspect."
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-01-2007, 11:16 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Spyware Doctor is also providing absolutely FREE version
http://www.computeractive.co.uk/spywaredoctor4/index
But I was not able to get the serial code, it was giving some error while submitting the form. I hv sent an e-mail to the staff
http://www.AskVG.com/
Vishal Gupta is offline
Old 04-01-2007, 11:48 PM   #5 (permalink)
Kiran.dks's Avatar
Good link anand. Thanks.
@ Vishal: I will check out the link, will get back.
Kiran Kumar R
Old 04-01-2007, 11:58 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
Guys, that Free Registration is now WORKING
register Spyware Doctor™ for Windows
but the d/l link is not Working. (i tried it with IE7 & Opera 9.10)
but one downside->Please note: this free version of Spyware Doctor does not include technical support and product updates.
__
s18000rpm is offline
Old 05-01-2007, 12:12 AM   #7 (permalink)
Microsoft MVP
Yes true! I checked my inbox and got the reply mail from them that they hv fixed the problem
Old 05-01-2007, 07:51 AM   #8 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
a review of spyware terminator on softpedia
http://www.softpedia.com/reviews/win...ew-30095.shtml
it says it is a resource hungry program
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ssk_the_gr8 is offline
Old 05-01-2007, 10:25 AM   #9 (permalink)
anandk's Avatar
u r welcome, kiran.
thanx 4 d grt info vishal. regd hope to get the serial soon.
got the serial
Microsoft® MVP
anandk is offline
Old 05-01-2007, 10:47 AM   #10 (permalink)
Kiran.dks's Avatar
I dont understand why are so many fields mandatory while registering for licence for Spywaredoctor? Company, Address, Phone number...etc., strange...
Kiran Kumar R
