I buy cheap DVD's 10-12 Rs. namely of Afa and National companies. Whenever I burn movies or songs over them. Then most of the times not all of the files end up running.
Some do not play possibly because they are corrupt and if trying to copy give a cyclic redundancy error.
Usually I burn them at 8X or 16X depending on whatever the DVD supports.
So should I burn them at lower speeds?
I do not really think it is something to do with the media as once I burnt a moser baer DVD and it also gave the same problem with one of the files not running.
I burn it from my friend's Lite On DVD writer.
So how to resolve the problem that is how should I burn the DVDs so all the files in it end up running?
The problem is not always but in almost 80% of the cases.
