04-01-2007, 07:11 PM
How to remove this error???
http://img120.imageshack.us/my.php?image=1hy5.jpg
Well recently i had a virus in my system....avg removed it
but after that every time system boots gets this message......
i Have unchecked msconfig but still cant help
Any suggestion?????
04-01-2007, 07:28 PM
Re: How to remove this error???
Yes. Your system was infected with Backdoor.Sdbot.N virus. Although avg has cleaned the virus, but the registry entry is still existing. You should remove it manually.
Download Ccleaner and run the registry cleaner.
Restart system. If problem remains, then
do the following registry editing manually.
>Start
>Run
>type regedit and click ok
Navigate to the key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run
In the right pane, delete the value:
"Windows Service Host" = "scvhost.exe"
RunServices
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\
Explorer\Advanced
In the right pane, change the value to:
"Hidden" = "1"
Exit the Registry Editor.
Source of registry editing and more about the virus: Click here
Kiran Kumar R
05-01-2007, 12:06 PM
thks for the reply but the stuff is still there...anymore suggestions
05-01-2007, 12:13 PM
Stuff is still there? Did you edit the registry as I said? It should work. Do it correctly.
Kiran Kumar R
05-01-2007, 01:13 PM
arrey did the registry stuff twice...first did it.....2nd time checked again...its still there...ill try again once more
05-01-2007, 05:46 PM
Microsoft MVP
Post ur HijackThis logfile and we'll be able to solve the problem!
05-01-2007, 05:53 PM
Logfile of HijackThis v1.99.1
Scan saved at 5:50:55 PM, on 1/5/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.5730.0011)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\Explorer.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\PROGRA~1\Grisoft\AVG7\avgcc.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\CallingID\CallingIDGlobal.exe
C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe
C:\Documents and Settings\a\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = 210.212.95.99:8080
F2 - REG:system.ini: Shell=Explorer.exe scvhost.exe
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: IeCatch5 Class - {2F364306-AA45-47B5-9F9D-39A8B94E7EF7} - C:\PROGRA~1\FlashGet\jccatch.dll
O2 - BHO: BitComet Helper - {39F7E362-828A-4B5A-BCAF-5B79BFDFEA60} - C:\Program Files\BitComet\tools\BitCometBHO.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar3.dll
O2 - BHO: gFlash Class - {F156768E-81EF-470C-9057-481BA8380DBA} - C:\PROGRA~1\FlashGet\getflash.dll
O2 - BHO: CallingID BHO - {FBF2401B-7447-4727-BE5D-C19B2075CA84} - C:\Program Files\CallingID\CallingIDIE.dll
O3 - Toolbar: FlashGet Bar - {E0E899AB-F487-11D5-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\fgiebar.dll
O3 - Toolbar: Igniteds Toolbar - {143896c6-a433-40a6-a790-77676256f1f6} - C:\Program Files\Igniteds\tbIgni.dll
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar3.dll
O3 - Toolbar: CallingID - {10134636-E7AF-4AC5-A1DC-C7C44BB97D81} - C:\Program Files\CallingID\CallingIDIE.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVG7\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKCU\..\Run: [Yahoo! Pager] "C:\PROGRA~1\Yahoo!\MESSEN~1\YAHOOM~1.EXE" -quiet
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O8 - Extra context menu item: Download All by FlashGet - C:\Program Files\FlashGet\jc_all.htm
O8 - Extra context menu item: Download all links using BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddAllLink.htm
O8 - Extra context menu item: Download all videos using BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddVideo.htm
O8 - Extra context menu item: Download link using &BitComet - res://C:\Program Files\BitComet\BitComet.exe/AddLink.htm
O8 - Extra context menu item: Download using FlashGet - C:\Program Files\FlashGet\jc_link.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~2\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~2\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~2\INetRepl.dll
O9 - Extra button: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\flashget.exe
O9 - Extra 'Tools' menuitem: &FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\PROGRA~1\FlashGet\flashget.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O10 - Unknown file in Winsock LSP: c:\program files\bonjour\mdnsnsp.dll
O11 - Options group: [INTERNATIONAL] International*
O16 - DPF: {2AF5BD25-90C5-4EEC-88C5-B44DC2905D8B} (DownloadManager Control) - http://dlmanager.akamaitools.com.edgesuite.net/dlmanager/versions/activex/dlm-activex-2.0.6.0.cab
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.safety.live.com/resource/download/scanner/wlscbase8460.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/wuweb_site.cab?1160934176234
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1159977893111
O16 - DPF: {E36C5562-C4E0-4220-BCB2-1C671E3A5916} - http://www.seagate.com/support/disc/asp/tools/en/bin/npseatools.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{52070802-3A65-43AA-A5E9-BB907ECD95BB}: NameServer = 208.67.222.222,208.67.220.220,202.88.130.67,202.88.130.5
O17 - HKLM\System\CCS\Services\Tcpip\..\{C9188953-8586-4F89-8B31-3919C84AE0E2}: NameServer = 193.113.200.200,193.113.200.201
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
O23 - Service: Bonjour Service - Apple Computer, Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
05-01-2007, 06:09 PM
Microsoft MVP
Fix following entries:
O16 - DPF: {2AF5BD25-90C5-4EEC-88C5-B44DC2905D8B} (DownloadManager Control) - http://dlmanager.akamaitools.com.edgesuite.net/dlmanager/versions/activex/dlm-ac tivex-2.0.6.0.cab
05-01-2007, 06:25 PM
Analysed the log file. The virus left over entry is still existing.
You should remove this entry.
Run HijackThis, checkmark
Click FIX CHECKED.
Restart computer.
Kiran Kumar R
05-01-2007, 09:00 PM
aaah thks its gone yup fixed it with hijack this........
thks again reps coming to u kiran and vishal....
btw wht do u do..u look to be an expert in windows reg stuff.....
also after removing all startup entries how was start up showing this trace........????any light on this is really helpfull
05-01-2007, 09:06 PM
Microsoft MVP
bcoz there was an entry of the file remaining in startup, thats why windows was giving error at startup even after the removal of virus
05-01-2007, 09:41 PM
I appreciate your feedback and nice to hear that your problem is sorted out..
scvhost.exe is not a genuine windows process. The actual process is svchost.exe that runs in Windows\system32 folder. So the left over registry entry is creating that error msg. HijackThis report clearly says that the entry still exists. All you needed to do was to remove that entry. That is what I suggested.
Kiran Kumar R
06-01-2007, 12:01 AM
And that tells you . . . Install . . . Avast . .  . . Its another free scanner and its good  .
Make a day good , and another day good , and another ...a happy lad is "born" from you :)
06-01-2007, 12:12 AM
first clean your temp and preftech folde and then clean your registry
06-01-2007, 04:23 AM
I dont think he will need to do that mate . .  he got it solved  . I just gave him a suggestion to use "avast" in future  .
07-01-2007, 10:51 AM
i have used avast...it detects avg as a virus sometimes so does nod32
08-01-2007, 09:49 AM
why not try Kasperkey
08-01-2007, 09:54 AM
The problem is solved already. I don't know why are you people proviking antivirus war again. Too many threads are closed recently for same reason.
Thread reported for closing: Reason problem solved
Kiran Kumar R
Search this Thread |
