Old 03-01-2007, 11:06 AM   #1 (permalink)
Default a strange problem
guys, im having a strange problem with my pc.
my pc is usually on for almost 12-13 hours a day.
two days ago, in the night at around 11pm i was surfing some sites in opera and all of a sudden, a popup
window appeared. i closed it but suddenly, my pc shut down.
after that, i tried to turn on my pc but no use.
Even bios screen didn't start. the processor fan rotated 2-3 times and the pc shut down again. i was tired at that time so i slept.
next day, my pc started fine, i worked on it all day. but in the night, at around same time,11pm, it turned shut down again automatically!!!
i tried my best to revive it but no use.
i disconnected my hard drive (i thought, it may be some virus)
and tried to boot from dvd-rom. but no use.
as earlier, even bios didn't start.
now, next day, that is today, it has started just fine. so im posting this.
guys, if u have any idea, plz help.
i haven't checked with my antivirus yet, but im goin to do it now.
hope to see some response from u!!
rajdeepsingh86 is offline
Old 03-01-2007, 11:12 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: a strange problem
Since you have not checked for virus, do it right away and post the result here. But for me it seems to be a problem of overheating or hardware failure. Check your SMPS.
Kiran Kumar R
Kiran.dks is offline
Old 03-01-2007, 06:08 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
^^ i concur; scan in SAFE MODE with ur av AND anti-spy like AdAware...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-01-2007, 01:06 PM   #4 (permalink)
ok, i tested my hdd with avast antivirus, and this is the report.
i had shceduled a boot time scan.
i have deleted all these files now.
and i had updated the antivirus just before checking my hdd.
01/03/2007 11:09
Scan of all local drives
File C:\Documents and Settings\Raj\My Documents\hp\auvj318a.exe\run.exe is infected by Win32:Zlob-LT [Trj], Deleted
File C:\Documents and Settings\Raj\My Documents\hp\auvj318a.exe is infected by Win32:Zlob-LT [Trj], Deleted
File C:\Documents and Settings\Raj\My Documents\hp\Super.AV.Converter.v5.3.650-DVT.ZIP\installer.exe is infected by Win32:VB-APL [Trj], Deleted
File C:\Documents and Settings\Raj\My Documents\hp\Super.AV.Converter.v5.37.680-DVT.ZIP\installer.exe is infected by Win32:VB-APL [Trj], Deleted
File C:\Documents and Settings\Raj\Templates\WowTumpeh.com is infected by Win32:Brontok-AA [Wrm], Deleted
File C:\drive\private\files\grub\grub.exe is infected by Win32:Brontok-AA [Wrm], Deleted
File C:\drive\private\files\ico & inf\ico & inf.exe is infected by Win32:Brontok-AA [Wrm], Deleted
File C:\Program Files\Common Files\Microsoft Shared\Translat\LicenseManager.exe is infected by Win32:Trojan-gen. {UPX!}, Deleted
File C:\Program Files\Common Files\Microsoft Shared\Web Components\WUpdMan32.exe is infected by Win32:Trojan-gen. {UPX!}, Deleted
File C:\WINDOWS\system32\Raj's Setting.scr is infected by Win32:Brontok-AA [Wrm], Deleted
File E:\fget Downloads\ebooks\linux\learning linux - a collection of 12 ebooks.zip\Learning Linux - A Collection of 12 Ebooks\Linux Unleashed, Third Edition\ch63\images\63-04.jpg Error 42125 {ZIP archive is corrupted.}
File E:\my docs\cool\Recreation\Entertain\Cat_Mice.exe is infected by Win32:Cursor [Joke]
File E:\my docs\my documents\hp\auvj318a.exe\run.exe is infected by Win32:Zlob-LT [Trj]
File E:\my docs\my documents\hp\auvj318a.exe is infected by Win32:Zlob-LT [Trj]
File E:\my docs\my documents\hp\Super.AV.Converter.v5.3.650-DVT.ZIP\installer.exe is infected by Win32:VB-APL [Trj]
File E:\my docs\my documents\hp\Super.AV.Converter.v5.37.680-DVT.ZIP\installer.exe is infected by Win32:VB-APL [Trj]
and also, plz do tell me how to check my SMPS?
and do u think that this could be a virus which has infected my MBR.
i use dual boot with fedora core 3 and i use GRUB boot loader.
i don't think, it could be overheating problem, coz i used it in summers too and it worked fine.
my processor is 1.9 GHZ, p-4
its 3-4 yrs old and has never given me any problems.
my hdd is 6 months old seagate barracuda 80 GB ATA drive
__________
guys,plz help me!
this happened again!
last night, at around 11 pm, my pc shut down again!
i have rewritten my mbr now, using fixmbr command from xp recovery console.
Last edited by rajdeepsingh86; 04-01-2007 at 01:06 PM. Reason: Automerged Doublepost
Old 04-01-2007, 01:13 PM   #5 (permalink)
Kiran.dks's Avatar
^^^ I clearly mentioned to first do a virus scanning. If your system is not infected, then it is the hardware problem. But now it is evident from scan report that your system is infected with Virus/malware.
Since you say that the problem is existing after scan, i suggest you to post your Hijackthis log file report here.
Kiran Kumar R
Old 04-01-2007, 01:19 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
damm windows!
just format it or reisntall it or go for linux(no viruses)
also do check cpu & system temp in BIOS just after shutdown see if it over heats
gary4gar is offline
